Mtlx authoring in VRED. Open Source Plugin now available.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
Thought I would make a post on here to share my open source plugin release. This now allows full mtlx authoring inside VRED via a node graph window.
Numerous examples and presets, preview shader once the material has been pushed to VRED. A handy validator for the material which can spot errors before and show diagnosis before sending. It uses each unique VRED versions mtlx library that it ships with. In theory this means versions 2024-2026 should work (I developed and tested this on 2027 version) but I cannot account for the python syntax changes between versions if there is a discrepancy.
Please use this post, my Linkedin or Github itself to share issues found, requests or anything else you can think of. I'd like to support this as much as I can until Autodesk release a true native one.
https://github.com/ScottRaffertyCG/VREDx
Cheers!
Scott
Pyre Labs founder
