More fun with Python transformations
dan.husted
dan.husted
I would like access the local transformation matrix for a given node.  My immediate need is to know if a node has an identity transformation, but I would like to the general process for accessing node data.  The getWorldTransformation function will retrieve the global position of the node, but I am interested in the position data for the node itself.
I am currently able to access all the data in the "attachments" section of a node, but I an struggling to get to the "matrix" and "isIdentity" fields.  And in general, how do I access the data for which there is no direct API?  The node editor is a pretty good tool for seeing the node data, but accessing the data seems a bit cryptic to me.
Thanks in advance for ant help you can provide.
j.kaestle
try this:
matrix = node.fields().getMatrix("matrix")
It's working fine in my script.
The isIdentity field should be accessable in the same manner.
best regards
Jochen
dan.husted
Jochen,
Thanks so much for your response.
I would have sworn I had tried that combination among the dozens I when through.  But this worked.
