Hello, I have seen the video in Youtube that Varjo VR-3 can support Leapmotion natively in VRED.
Could I use the other HMD plus Leapmotion to get the same result?
In the video, the Ultraleap Gemini, the fifth-generation leapmotion is used. Could I use the older ones?
If it possible, which version of VRED should I use?
Solved by TillmannDorsch. Go to Solution.
Hi, you should be able to use leapmotion integration with the Vred 2020, not 2021.
Following this you should have all the information.
I say "should" because the guide is very old and by now there is no support for leapmotion after Vred 2020 (2021 use python 3, and this is the problem)
best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Actually I want to know if other HMD with leapmotion could to same thing in the following video.
Hi, i think hand tracking is supported only on the Varjo headsets. But i'm not 100% sure.
Best
Chris
@luqiang.han @Christian_Garimberti
Hello. I know NOTHING about VRED, but I asked about this question internally, and got this response.
Out of the box with our blue VR hands, yes that's right. Only Varjo! But it is possible to to implemented hand tracking on your own via python getting the tracking coordinates and do whatever you want but obvious requires programming knowledge.
And a video they linked to:
https://youtu.be/2xoItW01OyI
Good luck. Let me know if this helps.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Currently, hand tracking in VRED is only supported for Varjo VR-3 and XR-3 out of the box.
