HTC wireless headset while using VRED?
RG_GO
Message 1 of 15
RG_GO
Hi Guys,
I am facing a problem using VRED along with wirelessly connected HTC Vive Pro Headset.
It works fine absolutely while navigating through SteamVR in VR mode, and the connection is stable. But it connection freezes immediately while trying to use VR in VRED.
  • Is this because of hardware, but i have two GTX 1080 card connected to my system? even tried with Quadro RTX 5000 but still, it freezes
  • OR is the because of huge data transfer occurring while using VR in VRED and the wireless adaptor from HTC can't handle it
Has someone ever been able to successfully use HTC wireless headset while using VRED?
Replies (14)
Message 2 of 15
faline.custodio.da.silva
@RG_GO
I can confirm that the we have customer that have successfully use the HTC wireless headset with VRED.
Have you tried to reinstall the driver?
Faline Custodio Da Silva
Message 3 of 15
RG_GO
Thannks for the reply, i can try to reinstall the wireless adaptor software and see if it works.
I must tell you that the wireless setup is working when being used with other application.
It just freezes while i VR in VRED. i only see black window in VR with never ending status bar .....
@faline.custodio.da.silva wrote:
@RG_GO
Message 4 of 15
michael_nikelsky
Have you tried not using the wireless but using a wired connection to see if that works? The wireless part should be completely invisible to any VR software, so for VRED there should be no difference between a wired and a wireless connection.
Michael Nikelsky
Sr. Principal Engineer
Message 5 of 15
RG_GO
Hi Michael,
When the wireless thing failed i tried using the wired connection and then it works fine, but wanted to use the Convenience of wireless as we have the setup here.
Message 6 of 15
michael_nikelsky
On what hardware are you trying to run? CPU, GPU and Network card would be interesting.
There are known issues on AMD Ryzen/Threadripper systems with the Vive Wireless adapter.
Michael Nikelsky
Message 7 of 15
RG_GO
I am Running on
CPU - Intel i7 Processor
GPU - Quadro RTX 5000 and 64 GB RAM
The Network card is the one which came with HTC wireless adaptor
Message 8 of 15
ionmcains
I'm working with it with VRED 2018 and 2019.2 and work fine with a lot of tris.
If you are using 2019 please be sure you choose the OpenVR option in the Display menu, not the VR Hero opstion that it's in the same pace the OpenVR option was in the 2018 release
Update: I test it with the same GPU (two 1080TI) config and works fine
Hope it helps
Message 9 of 15
RG_GO
Hope it helps
I am working with 2019.3 and can you please let me know the Tricks which you use to make it posible?
and when every i connect my VR i use OpenVR option.
I have tried using system with 2 GPU ( GTX 1080 x 2 ) and also with latest Quadro RTX 5000
Message 10 of 15
ionmcains
It works fine from the first time, no tricks were needed ( rare 😉 ).
Those are the software versions I'm using right now
Steam client 1556574584
Steam VR 1.3.23
Vive wirelless App 1.20190410
Nvidia driver 430.39
Have you test again using Cable conected HMD VRED still working?
I had work with VRED 2018 using the wifi adapter, maybe you can test another release to check if the problem comes from the VRED, Steam or Vive
This happens to you in different computers?
Hope it helps
Message 11 of 15
RG_GO
Steam VR 1.3.23
Hope it helps
Thanks for your reply and info, yes any info is a help
Yes i have tried connecting it with cable and it worked.
Can you please tell me, which network card you are using?
The one which came with the wireless setup ?
Message 12 of 15
ionmcains
Yes, is the card comes with the adapter. You can try to disable other
network devices just for test.
Are you using any script in your file?
It sound really weird
Regards
Message 13 of 15
Christian_Garimberti
Hi, I have installed the vive wireless adapter this afternoon, with Vred 2020 and everything works fine.
no tricks or special setup done.
chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 14 of 15
RG_GO
chris
Thanks for the information Garimberti,
I too will try to install VRED 2020 and reinstall my HTC wireless adaptor ,
Just to re confrim, did you also used PCI-e WiGig card, which came along with the wireless adaptor ?
Message 15 of 15
Yes, installed the pci card, mounted the "antenna" over the monitor , and download the vive wireless software.
Chris
