how to set paint type or chrome type via python script
nexzhou
nexzhou
i'm working on python script on vred, try to set paint type on UMetallicPaintMaterial, or chrome type on UChromeMaterial, via python script,
nd = findNode("chrome")
fds = nd.getMaterial().fields()
fds.setString("chromeType","highlyReflective")
nd = findNode("paint")
fds.setString("paintType","2-coat")
but script does not work with error:
vrFieldAccess::setField: Couldn't find field 'chromeType'
vrFieldAccess::setField: Couldn't find field 'paintType'
how to set paint type or chrome type via python script, is there any documentation of python api on setting chromeType or paintType , or shows chromeType or paintType parameters
need help for this question, thanks.
marcus_fritzen
There is no real documentation for all the fields of each material. However, you can use the node editor to figure out which field to set and additionally the type of the field (tooltip when the mouse is over the value in the node editor). In your case:
# Chrome type
mat = findMaterial("Chrome")
mat.fields().setInt32("metalType",4)
# Paint type
mat = findMaterial("Paint")
mat.fields().setInt32("paintType",1)
Cheers,
Marcus
Marcus Fritzen
Principal Engineer
nexzhou
Thanks a lot,
and I tried more to set chome "use roughness" to true with script below:
# chrome matte, set useRoughness ?
mat = findMaterial("chrome-matte")
mat.fields().setBool("useRoughness",True)
ends with error
error vrFieldAccess::setField: Couldn't find field 'useRoughness'
need help for this issue.
and if there is some documentation of python api on the things like these, that would be much better...
sinje_thiedemann
as Marcus has written, instead of documentation we have the Node Editor (a module in the GUI, Scene > Node Editor) where you can see all fields of a selected object. For materials, drag & drop them from the Material Editor into the module.
In this case, it is "isRough".
Kind regards
Sinje
nexzhou
thanks a lot. that is very helpful
