how to get the HMD model
wenyueyang08
wenyueyang08
hi,
how can I get back the name of the currently connected HMD's model from APIs? eg. 'varjo xr-3' or 'htc vive'
cheers,
Accepted solutions (3)
__daniel.lincoln__
When View, Display mode is set to OpenXR, these should work.
print(vrHMDService.getActiveOpenXRRuntimeName())
print(vrHMDService.getActiveOpenXRSystemName())
wenyueyang08
thanks for the reply.
how to get the view>display>openXR? I only can see openVR in the list.
also it shows 'vrKernelServices.vrHMDService' object has no attribute 'getActiveOpenXRRuntimeName' or '
getActiveOpenXRSystemName()'
is there any plugin or additional module need to be installed to get them work?
__daniel.lincoln__
Ok, for an XR-3, there is an 'OpenXR' toggle in the System tab of the Varjo Base software that needs to be enabled.
For Vive, it may depend on which model it is.
Christian_Garimberti
Hi, note then OpenXR in VRED is introduced in 2023.4 version. So you need at least that version.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
wenyueyang08
thanks! works in the latest version!
