Help with placing pattern
karlakurz
Message 1 of 9
karlakurz
I want to place the pattern you see below on my created cup, and I fail to postition it correctly.
The pattern shall surround the cup seamless and all-over with no repeats. How would you start? Shall I measure up the surface of the cup? Please advice hwo to manage in VRED....Tasse_11_Welle.pngTasse_Dekor.PNG
Replies (8)
Message 2 of 9
Christian_Garimberti
I think you have to use uv maps.
In the vred YouTube channel you will find videos on how to manage material and textures
https://www.youtube.com/user/VREDPRO
Also this video could help you.
https://youtu.be/9bLTLcND_D4
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 3 of 9
karlakurz
I am using the UV Editor, but he won't let mit sew the islands. I can unfold everything, but not select the separate pieces.
Does it depend on the tree structure on the left? Please help, because I want to go on...... I want to sew selected islands to fit in the pattern suitable.
Message 4 of 9
karlakurz
can please someone answer quickly?
Message 5 of 9
seiferp
I like the P...s Smiley LOL
Hope this helps  LINK
Message 6 of 9
karlakurz
thanks, I succeeded in working out!
Message 7 of 9
karlakurz
below you can see the result. Which lights would you recommend?
Is the shadow guaranted by picking the material :plastic reflective material?
Message 8 of 9
karlakurz
now I want to place the pattern on the packaging box.
How can I use the uv editor and the texture editor?
Please advise.
Message 9 of 9
karlakurz
What would be the best way the place the pattern?
Either divides in parts and then assigning to the walls?
Or assign the decal in one connected form?
<I also want to animate the box in form from moving the cap
