Hello all!
I hope I have not overlooked the problem and would like to ask for your advice here:
I'm currently trying (for the first time) via GPU raytracing to linearly reconstruct the beauty pass in Photoshop using the combined passes, however it doesn't work as usual with CPU raytracing: the contrasts look a bit different and the brightness differences don't match the beauty pass.
The following passes are used:
Combined Channels / Color Channels: Beauty (for comparison), Diffuse IBL/Light/Indirect, Glossy IBL/Light/Indirect, Specular Reflection, Transluency, Transparency Color, Incandescence, Background Color.
Export as Multi Layer .exr OR Single Passes as .exr -> Compositing in Photoshop 2021/2022 via Linear Add
No Tonemapping applied & 32 Bit Output Format.
With CPU raytracing it works fine - now I wonder if GPU raytracing is not yet supported or if I am missing something? I use a RTX 3090 and VRED 2022.3.
Many greetings and thanks!
