Hi guys, I am not that much into Python, maybe one of can help me out. We all know the F4 activates CPU Raytracing in VRED Pro after starting a new instance of VRED. The funny thing is that once you manually switch to GPU, VRED remembers the GPU flag during the session. Ideally, I would like VRED to jump into GPU RT after I start a new instance, rather than doing it manually. Does anyone know what to change or add in the prefs?
This is the default prefs script.
# Raytracing
KeyF4 = vrKey(Key_F4)
KeyF4.connect("setRenderQuality(VR_QUALITY_RAYTRACING)")
KeyF4.connect("setFaceNormalRendering(false)")
KeyF4.connect("setDiscontinuityRendering(false)")
KeyF4.connect("setAORendering(false)")
KeyF4.setDescription("Render Mode Raytracing")
Thanks in advance!
Z
Solved by wispoxy. Go to Solution.
Hi, something like this should work.
def gpu_rt():
setRaytracingMode(1) # GPU
vrFileIOService.newScene.connect(gpu_rt)
Dan
Hi Daniel, thanks for the quick reply, I tried it out, nothing is happening. No error message as such, but nothing is happening to the the icon. It still says CPU.
Python Script Modification: You can modify the Python script that handles the F4 key behavior. The default script looks like this:
Python
# Raytracing
To switch to GPU raytracing, you can add the following lines to the script:
Python:
def gpu_rt():
Activate GPU Raytracing Manually: If you prefer a manual approach, you can click the “New” scene icon after starting a new instance. This will trigger the GPU raytracing mode.
VRED 2021 introduced the ability to switch between OpenGL, CPU, and GPU raytracing.
