Hi all,
i am trying to use the VRED Custom Plugin as described here:
But VRED 2024.1 will not load the dll, I get an "unknown error". So, is that example realy working or am I doing something wrong. I compiled the sample with nmake ( Visual Studio 2019)
Thanks and best regards
Christian
Solved by Ruediger-Ambs. Go to Solution.
Please crosscheck if the DLL you generated is compiled for a 64bit system.
I had this request in the past and it turned out that the user compiled a 32bit version which will not work as VRED is a 64bit application.
Hello Rüdiger,
thanks for this advice ... this was exactly my problem!
Best regards,
Christian
