VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Counter Print-outs in the terminal
7 REPLIES 7
Message 1 of 8
357 Views, 7 Replies
Hi all,
It looks like that the counter output is being printed out to the terminal when VRED is looking for script plugins. Does anyone know the reason behind this printout? Is there any way to avoid this print-out on the VRED terminal?
Please find the attached screenshot. It is taken from Autodesk VRED 2021
Labels (2)
7 REPLIES 7
Message 2 of 8
Christian_Garimberti
Hi, maybe you have some scripts in your c:\users\USa\Documents\Autodesk\Vred-13.0\ScriptPlugins that print somenting?
best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
Message 3 of 8
in reply to: Christian_Garimberti
Yes, I have scripts in there but I investigated them but unfortunately couldn't find any command in the script that should print this out.
So, I was just wondering if it is printed out by VRED while loading the script or something like that.
Message 4 of 8
If you didn't already tried , Try to temporary remove all of them.
Then try to put back one at a time to find which one is the problem.
best
Chris
Message 5 of 8
chr33z
Or open the whole directory where you plugins reside in a text editor or IDE and do a full-text search over all files for 'print'. This should find the culprit.
Best,
(also) Chris
Message 6 of 8
Thanks for the suggestions. I have looked further into it and narrowed down the issue to this single command.
Message 7 of 8
chr33z
is there anything in your test.ui file that could generate this output? Here it seams that the function
loadUiType is generating this output. But this seems... weird. UI files are just a bunch of xml notation without any logic by itself.
Message 8 of 8
in reply to: chr33z
Yes exactly. That's the point, the UI file cannot print anything on its own (as per my knowledge).
This thing is puzzling me.
Technology Administrators
