Announcements
Chroma keying
ionmcains
Chroma keying
ionmcains
Using the movie example I manage to insert a video flawlessly but I have trouble with the transparency part.
a) Does VRED PRO supports any format with transparency?
b) I know VRED supports mp4 which doesn't have transparency, so I'm trying to insert a video with a chroma background. Looking around the documentation, inside vrMoviePlayer2, I've found enableChromaKeying which I think it should help me but I haven't been able to make it work.
Any help would be appreciated.
Christian_Garimberti
HI,
Have you tried to use an image sequence instead of a video?
So every image ca be a .png with transparencies.
Select the first image as a diffuse texture of a material, and apply the material to your object.
Obviously... if you can have the image sequence.....
Bye
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
ionmcains
I've tried using an image sequence and it works but the performance is not that great, whenever I put my VR glasses on the framerate drops, whereas if I use video the frame rate is great, that's why I was trying to use the chroma keying instead of the image sequence.
Thanks for the suggestion though!
