what is best practice to find the same nodes over different vred sessions?
nodeId
nodepath
unique nodepath
writing your own ids in the vrNodes
Any other ideas?
Best regards,
Marc
nodeId
nodepath
unique nodepath
Any other ideas?
Best regards,
Marc
Solved by michael_nikelsky. Go to Solution.
There is no general solution for this. The unique-nodepath is the best general option. Depending on your actual use case you might want to check the tags/metadata if you want to select groups of objects.
There is no unique identifier in VRED as it comes with its own set of issues (for example when merging scenes, duplicating objects, splitting and merging objects again and so on).
