VRED Forum
Welcome to Autodesk’s VRED Forums. Share your knowledge, ask questions, and explore popular VRED topics.
Anti-clockwise rotation
2 REPLIES 2
305 Views, 2 Replies
Hi, i would like to know if it's possible to rotate a element in a an anti-clockwise direction? Can you help me?
Tags (1)
Labels (1)
2 REPLIES 2
Christian_Garimberti
rotation is defined by the keys you set.
The rotation direction is always from a key to another key in the curve editor. Clockwise or counter-clockwise depends from your point of view...
So if you put 0 in the first key and 360 in the second you will have a rotation, if you put -360 you will have the opposite rotation.
Best
Chris
Christian Garimberti
Technical Manager and Visualization Enthusiast
Qs Informatica S.r.l. | Qs Infor S.r.l. | My Website
Facebook | Instagram | Youtube | LinkedIn
sinje_thiedemann
selected objects can be rotated with the Transform module (Menu Interaction > Transform).
VRED has a right-handed coordinate system, positive angle values (in degrees) rotate counter-clockwise, see also https://en.wikipedia.org/wiki/Right-hand_rule . Negative angles for the opposite direction.
If that's not what you're looking for, what do you mean by "element"?
Kind regards
Sinje
