Xref rename issue
Xref rename issue
andreas7ZYXQ
Xref rename issue
andreas7ZYXQ
I got some help to develop a code but i found out it doesnt do as i want some times.
It will change my name to 64CCBA.
But
It will change my path to..
.\64CCBA
It cuts out the .dwg..  Any ideas about this? So far the code saved alot of time since i run this on hundreds of files.
(Defun C:F64 ( / StringtoFind StringtoPut)
  (setq StringtoFind "61";(getstring "\nEnter string in Xref name: ")
	StringtoPut "64CCBA";(getstring "\nEnter new string here:  ")
	);setq
 (vlax-for MyXref (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)));<--go through all block objects
   (if (and
	 (vl-string-search (strcase StringtoFind) (strcase (vla-get-name MyXref)));<---if the name contains your string
	 (= (vla-get-isxref MyXref) :vlax-true);<---if it's an xref
     (progn
       (vla-put-name myxref (vl-string-subst StringtoPut;<---Change the name
			      (substr (vla-get-name MyXref)
				      (1+ (vl-string-search (strcase StringtoFind) (strcase (vla-get-name MyXref))))
				      (strlen StringtoPut));substr
			      (vla-get-name myxref)
			      );string subst
	 );vla-put-name
       (vla-put-path myxref (vl-string-subst StringtoPut;<---Change the Path
			      (substr (vla-get-path MyXref)
				      (1+ (vl-string-search (strcase StringtoFind) (strcase (vla-get-path MyXref))))
			      (vla-get-path myxref)
			      );string subst
	 );vla-put-path
       (vla-reload myxref)
       );progn
     );if
   );vlax-for
  (princ)
);defun
john.uhden
The first thing I see is that there is no checking on whether the new path\\name exists.
The second thing is if the StringtoPut is longer than StringtoFind then you could be losing path delimiters or part of the name extension.
The third thing is if there are multiple occurrences of StringtoFind in the path, e.g. C:\\ABC\\ABC\\ABC\\.  Which level are you intending to replace?
John F. Uhden
andreas7ZYXQ
i see..
I just want to replace the last one wich is the file name.
Do you have any idea how to change the code or someone else out there who are good at this 😛
john.uhden
Is it just the name you want to change?  Meaning you want to change the Xref to a different file, or do you want to reference the same file but change its name?  Your code appears to try to be changing the path as well.  Is that not true?
John F. Uhden
andreas7ZYXQ
My goal is to change part of a filename and also its path.
For example
E61-101-1.dwg
..\A\B\C\E61-101-1.dwg
to
E64CBBA-101-1.dwg
..\A\B\C\E64CBBA-101-1.dwg (64CBBA string can be 64 / 64A and so on. its not always the same number of characters in the string.)
with the code
	);setq..........
john.uhden
If the string lengths are not equal, then you can't use vl-string-translate.
John F. Uhden
andreas7ZYXQ
Actually i tweaked it a bit. Seems to work much better, didnt get any problems as before.
	);setq
   (if (and
     (progn
				      (strlen StringtoFind));substr
			      );string subst
	 );vla-put-name
			      );string subst
	 );vla-put-path
       (vla-reload myxref)
       );progn
     );if
   );vlax-for
  (princ)
;(command "qsave")
;(command "close")
);defun
