Open path lisp
Open path lisp
andreas7ZYXQ
Open path lisp
andreas7ZYXQ
Im looking for a lisp that will open a specified path.
I want to use the open command or similar build in autocad not startapp explorer..
defun c:run
and it will open and take me to a directory that looks like C:\xx\xx\xx\xx\xx\xx\xx\xx\xx\
at the moment i spen too much time going through my folders.
Anyone with great ideas?
Shneuph
How many paths do you need to save?  Can you not use the places shortcuts on the left side of the open dialog?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
andreas7ZYXQ
Of course!
Why make it more advanced than it has to be. Maybe my head just got stuck thinking about lisp 😛
Kent1Cooper
If you do decide that it would be convenient to have something like a little command name or a menu pick that will take you directly, in one step, into a particular folder, here's a way to do that [adjust the command name and file path to suit]:
;;;  ODXYZ.lsp
;;;  to Open a Drawing in the C:\X\Y\Z Folder
(defun C:ODXYZ ()
  (vla-activate
    (vla-open
      (vla-get-documents
        (vlax-get-acad-object)
      (getfiled "Select drawing:" "C:\\X\\Y\\Z\\" "dwg" 0)
(prompt "\nType ODXYZ to open a Drawing in the C:\X\Y\Z Folder.")
Kent Cooper, AIA
