XREF Destination File Summary
I am seeking advice for the following, and any help would be gratefully appreciated.
I would like to extract a list of the DWGs that a specific Drawing ( XREF) is referenced into. Whilst controlling document changes on a large project, I wish to summarise what layouts are affected by the changing of each XREF.
I cannot determine a method to do this, so imagine a lisp routine may be the solution, however I am open to suggestions. Thank you.
3wood
Do it in Reference Manager, not in AutoCAD.
I have explored this previously. As far as I can see this can only display drawings referenced into a DWG, as opposed to what DWG they are referenced into.
Thankyou for the prompt reply none the less.
rkmcswain
There is a step by step process on how to do this, described here.
R.K. McSwain     | CADpanacea | on twitter
Thank you.
The solution answers my query. Your help is appreciated.
An add-on or script that shows a live matrix of referenced files would be useful in the future.
One for Autodesk.
Thanks again.
Can the results be exported as an Excel Spreadsheet?
