Matrix : create, read, write
Hello everyone,
I'm a full beginner in AutoLISP, having a big issue with matrix. Impossible to find clear help, so I require your advices.
I succeded to create a matrix of 3 dimenssions, (almost) succeeded to read an element... but impossible to write one element.
Have you succeedded or found something about this issue ? If not, how to skirt the problem ?
Below are my code to create a matric l x c x p containing the element a :
(defun ctab3 (a l c p / lin col pro)
 (repeat l (setq lin (cons a lin)))
 (repeat c (setq col (cons lin col)))
 (repeat p (setq pro (cons col pro)))
And there to search an element in lst (matrix l x c x p) at the rank l-c-p (but the transfer of the list doesn't work) :
(defun stab3 (lst p c l)
 (nth l-1 (nth c-1 (nth p-1 lst)))
stevor
Perhaps you should show a few examples of your arrays with their elements in columnar form.
S
scot-65
What you are showing in the first code quote panel are three LISTs.
In other words, three one-dimensional arrays.
To make it into a two dimensional array (matrix) is to
bundle these three lists into a single list:
(list
(repeat l...
(repeat c...
(repeat p...
);list
A pseudo 3-dimensional list can be described as follows:
(list
(cons a (list b c d))
(cons e (list f g h))
);list
This works well when reading a INI-structured external file
where a (and e) is the [Header] inside the INI file.
First Dimension: Left and Right.
Second Dimension: Up and Down.
Third dimension: Towards and Away.
Fourth Dimension: Array or List inside any one of these nuggets.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
shoukat
(defun stab3 (lst p c l) (nth (- l 1) (nth (- c 1) (nth (- p 1) lst))) )
martti.halminen
You have hit one of the weak points of AutoLISP: unlike most programming languages, it doesn't have a native array datatype, and rather poor tools for building your own.
I see three possible ways to do this:
A) Building this on top of AutoLISP lists. This is made somewhat clumsy by the limitation that in AutoLISP (unlike other Lisp implementations) lists are essentially read-only once created: the only way to change one is to copy it, changing some items in the copying.
B) Using ActiveX safearrays, see the vlax-make-safearray and vlax-safearray-... functions.
C) Doing this part of your program in some other language. For example I am maintaining a large AutoLISP program where any parts needing a more capable language are implemented in Common Lisp.
hgasty1001
Just a simplistic approach:
(setq matrix (list (list a11 a12 a13) (list a21 a22 a3) (list a31 a32 a33)))
(defun aij(m i j)
 (nth (- i 1) (nth (- j 1) m))
(defun DotProduct (v1 v2)
(apply '+ (mapcar '* v1 v2))
And so on...
If you need a really good start on matrix algebra with Autolisp, you can visit: http://www.lee-mac.com/mathematicalfunctions.html#matrixvector
Gaston Nunez
