X & Y Differences
X & Y Differences
X & Y Differences
I know this is a little rude, but I am rusty on autolisp.  I dug out my old book, but it still might take me some time to do what I want.
I'm sure somebody could whip this out in no time, and it would be greatly appreciated:
I'd like to pick two points
have it print to the command line e.g.
   the difference between the X's (rounded to the 2nd Place e.g. -0.02)
   the difference between the Y's (rounded to the 2nd Place e.g. -0.02)
Then prompt for two texts and change the
  content of the first text to the absolute value of the X difference e.g. 0.02
  content of the second text to the absolute value of the Y difference e.g. 0.02
Pretty simple for someone who knows autolisp, heck I can't even remember the difference between CAR and CDR,
Thank you!
hmsilva
Hello cadger,
as a starting point
(defun c:demo ( / dimz ent1 ent2 pt1 pt2 sel1 sel2 xs ys)
  (if (and (setq pt1 (getpoint "\nEnter the first point: "))
           (setq pt2 (getpoint "\nEnter the second point: "))
    (progn
      (setq dimz (getvar 'DIMZIN))
      (setvar 'DIMZIN 0)
      (princ (strcat "\nThe difference between the X's = " (setq xs (rtos (- (car pt1) (car pt2)) 2 2))))
      (princ (strcat "\nThe difference between the Y's = " (setq ys (rtos (- (cadr pt1) (cadr pt2)) 2 2)))
      (setvar 'DIMZIN dimz)
      (if (and (setq sel1 (entsel "\nSelect the difference between the X's Text: "))
               (= (cdr (assoc 0 (setq ent1 (entget (car sel1))))) "TEXT")
               (setq sel2 (entsel "\nSelect the difference between the Y's Text: "))
               (= (cdr (assoc 0 (setq ent2 (entget (car sel2))))) "TEXT")
               (not (eq ent1 ent2))
        (progn
          (entmod (subst (cons 1 xs) (assoc 1 ent1) ent1))
          (entmod (subst (cons 1 ys) (assoc 1 ent2) ent2))
        (princ "\nYou didn't select valid texts... ")
    (princ "\nYou didn't enter valid points... ")
  (princ)
Hope this helps,
Henrique
Kent1Cooper
Because of the absolute-value component in the last part of the request, I at first thought of saving each difference as a number rather than as a string right off the bat, so that (abs) could be applied to it.  But then you'd need to apply (rtos) twice, once to report to the Command: line [not absolute value] and once for the Text content [with (rtos (abs ...))].  Perhaps a simpler way would be to just strip the minus sign off the string if it starts with one, by replacing the above with:
    (entmod (subst (cons 1 (vl-string-trim "-" xs)) (assoc 1 ent1) ent1))
    (entmod (subst (cons 1 (vl-string-trim "-" ys)) (assoc 1 ent2) ent2))
Kent Cooper, AIA
hmsilva
My bad,
have not read the:
'Then prompt for two texts and change the
  content of the second text to the absolute value of the Y difference e.g. 0.02'
Thank you!
Henrique
thank you!
i finally went with this for now:
(defun c:get (/ PT1 PT2 SEL1 SEL2 XS YS)
(SETQ PT1 (GETPOINT "\n PICK SURVEY POINT: "))
(SETQ PT2 (GETPOINT "\n PICK PLAN POINT: "))
(princ (strcat "\nThe difference between the Y's = " (setq ys (rtos (- (cadr pt1) (cadr pt2)) 2 2))))
;(setq xs (rtos (ABS ((- (car pt1) (car pt2)) 2 2))))
;(setq ys (rtos (ABS ((- (cadr pt1) (cadr pt2)) 2 2))))
(progn
(PRINC)
your help got me flying right off the bat.. now i can spend some time relearning all the functions... for some reason the top lisp post gave me an error (does't tell me what line) so i had to reduce it to the above, but thanks for the great start!
regards,
cadger
hmsilva
@Anonymous wrote:
thank you!
You're welcome, cadger!
The top lisp post should not give an error...
'It is always a good principle to validate all data, before using it as an argument.'
I did made some modifications in your code, to to prevent a message like this
; error: bad argument type: numberp: nil
if the user press enter key, insted enter a valid point...
Henrique
This maybe works!
(defun C:do-it(/ p1 p2 dist x-dt y-dt)
  (setq  p1 (getpoint "\nPlease pick the first point:\n")
  p2 (getpoint "please pick the second point:\n")
         dist (distance p1 p2)
         x-dt (abs (- (car p1) (car p2)))
        y-dt (abs (- (cadr p1) (cadr p2)))
  (prompt (strcat "\nDistance of the Points " (rtos dist) "mm\n"
                          "Δx:  " (rtos x-dt) "mm\n"
                          "Δy:  " (rtos y-dt) "mm\n"
