Writing a list to txt-file
thomas.schive
thomas.schive
Hello!
So - I have a list made by appending a wild card conditions from another:
(foreach x ListA
(if  (wcmatch x "111*")
(setq ListB (append (ListA (list x)))
However, I would like my ListB to be written to a txt file! I have experimented with:
(mapcar (function (lambda ...
to place (princ)'s in order to create space shifts in a txt document.
... But it does not seem to work properly ...
Is there a way to take ListB's content and write it to a txt-file?
john.uhden
Try (vl-princ-to-string B)
Though you will lose some precision of any reals in the list(s).
John F. Uhden
CodeDing
@thomas.schive ,
You could write your entire list to the text file with vl-prin1-to-string then use the READ function to store it as a variable again. Is this what you're looking for?
(setq fName "c:\\users\\myName\\myFolder\\myFile.txt")
(setq f (open fName "w"))
(write-line (vl-prin1-to-string ListB) f)
(close f)
(setq f (open fName "r"))
(setq str (read-line f))
(close f)
(setq ListB (read str))
Best,
~DD
ВeekeeCZ
What do you mean by "space shift"?
Would you give us an example of lista and desired txt file outcome?
