Write a text without open dwg file
islerahmet06
islerahmet06
Hi again
i have lots of dwg files in same file (for example c:\users\)
i insert a text like "hello" all of these files one by one
is there any easy way to do this?
text coordinates, height etc might be same
ВeekeeCZ
You need ScriptPro HERE
Then you'll need a simple script like
TEXT
0,0
2
0
HELLO
... just what would you do if you enter the text thru the command-line.
islerahmet06
thanks for your answer but i dont have permission to setup any program at my work but i will try it myself at home
 i will write when i try 🙂 thanks a lot.
jamieq
Take a look at Lee-Mac's ODBX Wrapper.
The function to use with it could be something like:
(defun addtext (doc)
  (vla-AddText (vla-get-ModelSpace doc) "Whatever text." (vlax-3d-point 0 0 0) 12)
This will put the text "Whatever text." at 0,0,0 with a height of 12 (inches, or whatever units you use). Use it like:
(LM:odbx 'addtext dwg t)
Variable dwg needs to be a list of drawings names. You can make it nil and it will prompt you for a folder, and will run addtext on every drawing in that folder. The t saves each drawing once the text is added.
