Width,depth,length in a table
Hello
Hope you are all doing well ,I am a mechanical engineer working as air conditioning system design engineer . I was wondering if anyone can help me in developing a lisp since my kn owledge about lisp programming is extremely at a low level . My plan is to have a lisp that create a table for duct information .. which are as follows
Width , depth , length
Let us say it will work as follow :
Command : DWT(since this Table will help in calculating duct weight)
Autocad : please enter width value
Here the user will enter width of the duct and press enter
Autocad : please enter depth value
Here the user will enter the depth of the duct and hit enter
Autocad : please select legth of duct
Here the user will select the line that represents the length of duct and press enter
And auto cad will repeat the cycle till the user select close(C)  then cad will reply
Autocad : please specify the  point for the table
Then it will place a table with width and depth and length
I hope you got my point ..can this idea be implemented ? Appreciate anyone who can help
Kind regards
here is a link for dwg sample of what I mean
https://drive.google.com/file/d/1Wa0jOtYifxck-KOy2ds99BHF8L1v5AeI/view?usp=sharing
Sea-Haven
My suggestion is work in a 2 1/2 3D mode so a duct would be a rectang, so can get length and width, but use thickness for height can then just select say all rectangs on a layer and table can be made from the 3 properties.
Draw rectang, Then Thickness, then -Vpoint 1,1,1
Thank you for your immediate reply
Regarding your point of view it will help a lot and will save a lot of time and effort .. but since most of our work are shop drawings our layouts are in 2D with text lables on it so I think converting ut to 3D will take more time.
Please forgive my low knowledge but isn't my idea could be implemented ? .. I dont know how lisp work so I cant answer to this question so please let me know 😄
calderg1000
Regards @Anonymous
I found this code and adapted it to your requirements
;;;For bigal 2-08-2015
;; Tharwat 26. 08. 2015 ;
;; mods by BIGAL 29.08.2015 now as table
;;;Edit for Calderg1000, 18-12-21.
(defun c:DWT(/ doc curspace pt1 s nline numrows numcolumns rowheigth colwidth objtable x y r pntlist pins itm)
(vl-load-com)
(setq curspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setvar "dynmode" 1)
(setq pt1 (vlax-3d-point (getpoint "\nEnter a point for TABLE Top Left Corner: ")))
(setq nline(getint "\nIEnter the number of conduits:"))
(setq numrows (+ 2 nline)
	numcolumns 4
	rowheight 7
	colwidth 25)
(setq objtable (vla-addtable curspace pt1 numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "Table for Duct Information")
(vla-setcolumnwidth objtable 0 15)
(vla-setcolumnwidth objtable 1 25)
(vla-setcolumnwidth objtable 2 30)
(vla-settext objtable 1 0 "Item")
(vla-settext objtable 1 1 "Width")
(vla-settext objtable 1 2 "Depth")
(vla-settext objtable 1 3 "Length")
(vla-SetTextHeight Objtable (+ acDataRow acHeaderRow acTitleRow) 2.0)
(vla-SetAlignment Objtable acDataRow acMiddleCenter)
(setq x 1)
(setq y 2)
(setq r 0)
(repeat nline
  (setq wd (getreal "\nPlease Enter Width Value:")
  	dp (getreal "\nPlease Enter Depth Value:")
	s(entsel "\nPlease Select length of Duct:"))
(setq e (vlax-ename->vla-object(car s))
	itm(vla-settext objtable y 0 (rtos x 2 0)))
(vla-settext objtable y 1 (rtos wd 2 2))
(vla-settext objtable y 2 (rtos dp 2 2))
(vla-settext objtable y 3 (rtos (vla-get-length e) 2 2))
(setq pins (vlax-curve-getpointatparam e (* (+ (vlax-curve-getstartparam e) (vlax-curve-getendparam e))0.5)))
(vl-cmdf "text" "j" "mc" pins 1 0 (strcat "Duct " (itoa (1+ r))))
(setq x (1+ x ))
(setq y (1+ y ))
(setq r (1+ r ))
);Repeat
(princ)
); defun
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Dear @calderg1000
I can't say more than Thank you !
You really made it the exact way I want and it works like a charm
Thank you so much for your time and help
Sea-Haven
I would still look into storing extra info if you want just a Line only using xdata its not that hard you would store the width and height attached to the line. Much easier as just select say a layer of lines no need to keep entering width etc.
Afralisp xdata is a real good tutorial about using xdata very well explained. It is what you want 1st tutorial is about a LINE.
Extended Entity Data - Part 1 | AfraLISP
So you would have 2 lisps set height & width and draw duct. A 3rd would be make table.
If you get stuck post again.
