Copy text value to replace for existing texts
minh.dxuan
Message 1 of 8
minh.dxuan
Dear @https://forums.autodesk.com/t5/user/viewprofilepage/user-id/1779365,
Please help me. I need to copy text value (from text or from field text) to replace for other existing texts. There are 2 problems now I meet:
1. I need to copy 2 files into 1 folder (ACA-Trap.LSP and mat.LSP) and load 2 lisps (ACA-Trap.LSP and mat.LSP) to use the command "mat". I think use 1 file and load it only is more convenient than use 2 files and load 2 files.
2. If the value of existing field text is the same as source text, when I applied "mat" from source text to existing field text, the field still exist. In this case, I need all destination field text will become text without field.
Please refer the files and video.
Thank you so much in advance.
Replies (7)
Message 2 of 8
minh.dxuan
And this is the video describes the 2 above problems.
Message 3 of 8
hak_vz
You can simply join contents of two lisp files into single one in your editor.
Or you can add both files to startup suite (tools->load applications and startup suite button). This way functions will be available in any new file you open
Miljenko Hatlak
Message 4 of 8
ВeekeeCZ
You can use this one for string copy. If you want to copy a field, use Lee's CopyField.
Message 5 of 8
devitg
@minh.dxuan find attached both  file in one.
Message 6 of 8
minh.dxuan
Many thanks @https://forums.autodesk.com/t5/user/viewprofilepage/user-id/5530556 for your suggestion. I am newbea and blank brain with lisp code. I hope I can write the code soon.
Message 7 of 8
minh.dxuan
Hi @https://forums.autodesk.com/t5/user/viewprofilepage/user-id/1779365, your lisps always are always extreme. I loaded and it runs very smooth.
Thank you so much.
Message 8 of 8
minh.dxuan
Hi Devitg, many thanks for your help and hopefully I will receive your support in future.
