why crash on switch layout?
xinxirong
xinxirong
(vl-load-com)
(defun LM:ss->vla ( ss / i l )
(if ss
(repeat (setq i (sslength ss))
(setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
(vlr-miscellaneous-reactor nil '((:vlr-layoutSwitched . ctab_willchange)))
(defun ctab_willchange (calling-reactor Info / obj)
  (foreach obj (LM:ss->vla (ssget "x" '((0 . "viewport"))))
     (VL-CATCH-ALL-APPLY 'vla-put-ViewportOn (list obj :vlax-false))
Maybe it has switched ,so I can not put the viewport off.But I use this reactor,also crash
(vlr-editor-reactor nil '((:vlr-sysVarWillChange . ctab_willchange )))
  (if (or (= (strcase (car Info)) "CTAB") (= (strcase (car Info)) "TILEMODE"))
Moshe-A
@xinxirong  hi,
This call (ssget "x" '((0 . "viewport"))) also return the layout viewport (the outside one) which you are not allow to modify. before you turn the viewport display to Off check the viewport id and if is 1, skip it 😀
Moshe
