When LISP executes AUTOCAD Text Window Pops Up
My routine appears to work properly in my environment, but everytime that I run the LISP the command history text window pops up.
Bytheway, I am fairly new to LISP.
See attached txt file.
Thanks!
scot-65
A quick look here I did not see errors.
There are two routines in this file - Which one causes the (textscr)?
Substitute "-layer" with ".layer", etc.
Try adding (graphscr) before the (princ).
And Welcome to these Forums!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Thanks for the quick reply!
Well, if I run the routine "cpurge" by itself it causes the command window to pop-up.
After incorporating both of your suggestions my LISP runs fine
1. changing (-layer) to (.layer) or (-purge) to (.purge)
2. adding (graphscr) before (princ)
Thank you!
