What is a good way to create mleaders from a *.csv file?
I want to open this csv file, and have it draw a multileader at each x,y coordinate using each additional comma separated value as a new line in the multileader.
Can someone point me in the right direction?
I attached a file of my example.  Number of lines in the text file could be arbitrarily long.
Thank you,
hmsilva
@Anonymous wrote:
... and have it draw a multileader at each x,y coordinate ...
Hi smay8399,
you only have one point per text line, is your mleaderstyle defined without leader, only text?
Or are you going to calculate the second point from the that point?
Henrique
I want to calculate the leader and the landing from the first point. The X,Y point is the center of a manhole or other items of interest on the drawing. I have an excel sheet that I'm exporting the *.csv from
hmsilva
Untested...
(defun c:demo (/ *error* parse file fname line lst pt str x y)
   (defun *error* (msg)
      (if file
         (close file)
      (cond ((not msg))
            ((member msg '("Function cancelled" "quit / exit abort")))
            ((princ (strcat "\n** Error: " msg " ** ")))
      (princ)
   (defun parse (str del / lst pos)
      (while (setq pos (vl-string-search del str))
         (setq lst (cons (substr str 1 pos) lst)
               str (substr str (+ pos 2))
      (reverse lst)
   (if (and (setq fname (getfiled "" "" "csv" 8))
            (setq file (open fname "r"))
      (progn
         (read-line file) ; to remove the header
         (while (setq line (read-line file))
            (setq lst (parse line ",")
                  x   (atoi (car lst))
                  lst (cdr lst)
                  y   (atoi (car lst))
                  lst (cdr lst)
                  pt  (list x y)
                  str (vl-string-right-trim
                         "\\P"
                         (apply 'strcat (mapcar (function (lambda (x) (strcat x "\\P"))) lst))
            (command "mleader" pt (polar pt (* pi 0.25) 50.0) str); change the polar point...
   (*error* nil)
   (princ)
Hope this helps,
Henrique
Thanks, that helps a lot.  I will post my final lisp file when it is done.
hmsilva
You're welcome!
Glad I could help
Henrique
