weird function?
weird function?
Moshe-A
Mentor Mentor
Message 1 of 20
weird function?
Moshe-A
hey experts,
The following function returns a list of 4 angles and than causes AutoCAD to stuck and the cause of this is (angtos) can any one figure why?
(setq _degrees
   (lambda ()
     (mapcar
       (function
	 (lambda (ang)
	   (angtos ang 0 4)
       (list (/ pi 4) (* (/ pi 2) 3) (* (/ pi 2) 5) (* (/ pi 2) 7))
Replies (19)
Message 2 of 20
paullimapa
well this part of your code:
(mapcar
       (function
	 (lambda (ang)
	   (angtos ang 0 4)
Returns this:
("45.0000" "270.0000" "90.0000" "270.0000")
But when you do this you get a function:
(lambda ()
     (mapcar
       (function
	 (lambda (ang)
	   (angtos ang 0 4)
AutoCAD returns:
#<SUBR @000001e69554f318 -lambda->
Paul Li
IT Specialist
@The Office
Message 3 of 20
ВeekeeCZ
Exactly, what is the purpose of the outer lambda?
>> (setq _degrees (mapcar '(lambda (a) (angtos a 0 4)) (list (* pi 0.25) (* pi 1.5) (* pi 2.5) (* pi 3.5))))
or
>> ("45" "270" "90" "270")
...it depends on 'dimzin setting.
Message 4 of 20
Moshe-A
@ВeekeeCZ ,
(setq _degrees (lambda (args)   ....    ))  ; create anonymous function
usage:
(_degrees) ; this returns the list as needed but than AutoCAD stuck
the result is the same even if changing it to regular function.
for test, if you replace (angtos) to (rtos) ... autocad does not stuck
(on my laptop on AutoCAD 2024 😀)
edit: sorry i had a mistake and fix it but this does not change the result, my AutoCAD get stuck
(defun degrees ()
  (mapcar
   (function
     (lambda (ang)
       (angtos ang 0 4)
   (list (/ pi 4) (* (/ pi 4) 3) (* (/ pi 4) 5) (* (/ pi 4) 7))
Message 5 of 20
ВeekeeCZ
@Moshe-A
sorry, I tried 2000 and 2025, and I don't see any issues. No lag, no stuck.
By the way, why do you prefer this construct? If I remember correctly, it was not recommended for some reason... What's the benefit of it over a classic named function?
(defun _degrees () ...)
Edit: I see you used defun now... anyways, can't replicate the issue. Sorry.
Message 6 of 20
paullimapa
no problems in my 2024.1.6 whether (_degrees) or (degrees)
Paul Li
IT Specialist
@The Office
Message 7 of 20
Moshe-A
@ВeekeeCZ
@paullimapa
thanks for your help,
many years ago i saw here some one used it and like it. than i went back to the documentation and read this
Use the lambda function when the overhead of defining a new function is not justified. It also makes your intention more apparent by laying out the function at the spot where it is to be used.
and thought it is more efficient but now that you are asking i have second thoughts, maybe assigning it to a variable  actually defines a regular function?!
Moshe
Message 8 of 20
ВeekeeCZ
If you ask me, I would probably do something like this
(defun :angtos04 (rad) (angtos rad 0 4))
(setq angdec (mapcar (function :angtos04) (list (/ pi 4) (* (/ pi 4) 3) (* (/ pi 4) 5) (* (/ pi 4) 7))))
or just...
(setq angdec (mapcar ':angtos04 (list (/ pi 4) (* (/ pi 4) 3) (* (/ pi 4) 5) (* (/ pi 4) 7))))
But I might not understand the context of your work. Also, I am not a theoretician, so it's just me.
Still, dunno why you got 'angtos stuck.
Message 9 of 20
dbroad
To me, this would be preferrable and more readable to just assign the list to a variable: (setq degrees '("45.0000" "270.0000" "90.0000" "270.0000"))
What's the point of hiding logic inside a function?  What is weird is why those angles and why the different ways to calculate the 270 degree angles?
Architect, Registered NC, VA, SC, & GA.
Message 10 of 20
Sea-Haven
I have used this for use within lisps where need an angle as radians used multiple times in calcs. The function DTR RTD have been used for years so not sure why would need to do multi angles.
(setq pi45 (* pi 0.25) pi2 (/ pi 2.) pi135 (* pi 1.25) pi180 pi)
Could do the same for degrees.
Message 11 of 20
Moshe-A
@ВeekeeCZ
@paullimapa
update:
On my office machine with R2023 it works fine
on my laptop R2024 on new clean installation (only 10 day ago) it stuck
still if i replace (angtos) with (rtos) just for test it does work without...
any way guys thanks 😀
Moshe
Message 12 of 20
john.uhden
@Moshe-A ,
I think the lambda function has to be preceded by either an apostrophe or the function function.
The 2nd example starts with (lambda ...) without any prefix so that's as far as it gets... returning the value of the lambda function itself and nothing else.
John F. Uhden
Message 13 of 20
john.uhden
@Sea-Haven ,
I like your style.  Decades ago I adopted a similar convention...
(setq 1/4pi (* 0.25 pi)
          1/2pi (* 0.5 pi)
          3/4pi (* 0.75 pi)
          2pi  (* 2 pi)
    ;     etc.
At the time I thought that recalling a value by symbol name had to be faster than the calculation to create the value.
But since those days I think someone here (probably @Kent1Cooper) taught me that unless the value requires numerous steps to create, 'tis faster to create the value on the fly.  I don't think I ever tested.
Nevermind.  The tests I made on a tiny function revealed a tie.
John F. Uhden
Message 14 of 20
Moshe-A
update:
the issue comedown to this:
at VLIDE console key in this expression
OK, return "90", AutoCAD window filp on and the VLIDE pops on the command line, AutoCAD enters to an unstable state, vlide is stuck and can be close only from Task Manager.
Could not be i am the only one having this?!  (AutoCAD 2024 Vanila)
i have checked Autodesk Access and there are no updates waiting to download.
Message 15 of 20
ВeekeeCZ
@Moshe-A
you're a programmer. you should know the drill... you need to break down the problem into pieces.
(angtos (* pi 0,4) 0 4)
from what see...
PI symbol, does it behave correctly, what about different calculations?
ANGTOS function, again, is definition ok? Can't that be redefined?
Units.. is there an issue with all units conversion, or just decimal? In ACAD, unit setting in a regular drawing, any sort of issues there?
Can't Windows be an issue? What about some country setting... how about Excel, all good there?
I can't really help you... you don't need to answer all the questions for me... I just wanted to point out possible causes to check, and maybe you'll come across something that will give you a clue and help you resolve the problem. If you've already done so, sorry, but you're not mentioning it.
Good luck!
Message 16 of 20
paullimapa
Stopped using Vlide since Autodesk switched to VS Code. I’d recommend the switch
Paul Li
IT Specialist
@The Office
Message 17 of 20
Moshe-A
@ВeekeeCZ
It only happen under vlide on R2024
On R2022 (on the same computer) it is working very well.
My machine: normal Laptop with windows 11
thank you
Message 18 of 20
Moshe-A
@paullimapa
Message 19 of 20
calderg1000
Regards @Moshe-A
After the first lambda has been executed.
What sense would it make to use lambda without arguments and without an expression, on a list. Even more so without an apostrophe or preceded by "function"
In my opinion, this expression does not make sense. Its evaluation only results in the parameter falat message. But still my C3D will see. 2025, does not crash
(setq  _degrees
(lambda() (list "45.0000" "270.0000" "90.0000" "270.0000"))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 20 of 20
Moshe-A
@calderg1000 ,
@calderg1000 wrote:
Regards @Moshe-A
the answer to this is in my reply on message #7
thank you
Moshe
