weight calculation lisp working in autocad 2014 but not working in 2016
Hi, I have this lisp routine that used to work in autocad 2014 but is acting up in version 2016.
It is used to calculate the weight of a wall (concrete) with an opening. (2d)
(defun c:gewicht ()
  (progn
    (SETQ dikte (GETREAL "\ndikte van het paneel?: (m) "))
    (setq DZIN (getvar "dimzin"))
    (setq ins 1)
    (while
      (setq ins (getpoint "\nPick Number Location: "))
       (command "dimzin" "0")
       (command "-hatch" ins "")
       (command "area" "o" "l")
       (command "erase" "l" "")
       (setq AR (getvar "area"))
       (setq
     gewicht (strcat (rtos (* (getvar "area") dikte 0.2450) 2 2)
             "  kg"
       (command "mtext" ins "h" 15 "j" "mc" ins gewicht "" "")
       (command "dimzin" DZIN)
    )                    ;WHILE
    (princ)
So what is it doing wrong?
The 2014 version it would create a hatch based on island detection.
It would get the area from the last created element (hatch) calculate the weight.
Add the text
Delete the hatch.
version 2016: adds the hatch, but only calculates the weight of the island.
Deletes not only the hatch but the original drawing too.
So version 2014 would give me a weight of 8000+kg (20cm think concrete wall (0.2m)
Version 2016 only 2000+kg
Can someone help me find out what i did wrong?
Ajilal.Vijayan
As this lisp routine is using acad hatch to calcualte the area, make sure the Hatch settings is detecting the island.
Spoiler
Thank you, But it seems that it was a problem with annotative hatch i changed my code to: (command "-hatch" "an" "n" ins "") and now it is working again.
