chain selection with layer filter
robert06
Message 1 of 10
robert06
There is this great lisp of chain-selecting objects by Lee-Mac http://www.lee-mac.com/chainsel.html
How to add layer filter to select objects only on layer of the picked object?
Replies (9)
Message 2 of 10
hmsilva
Hi Robert,
Lee Mac's 'ChainSelV1-0.lsp', use a selection filter 'sf' in the ssget function.
To not have to test all objects layer inside the 'repeat' function, I would suggest to change the selection order, first test the 'en' section set using the 'sf' filter, get the layer associated to the selected object, pass it to a second selection filter, and apply this selection filter to the 's1' selection set...
Hope this helps,
Henrique
Message 3 of 10
robert06
Thank you and sorry for replying so late, I took me some time to study this, no luck yet.
Message 4 of 10
hmsilva
Hi Robert!
Did you try my previous suggestion?
Henrique
Message 5 of 10
robert06
Hi, to be honest, it goes off my skills.
Message 6 of 10
hmsilva
Ok!
Robert,
if no one step in, tonight, I'll see what I can do.
Henrique
Message 7 of 10
hmsilva
Hi Robert,
the attached 'ChainSelV1-0_h1.lsp' was modified by me, from Lee Mac's 'Chain Selection - ChainSelV1-0.lsp', to perform a chain selection by layer, I did change the original command name from 'cs' to 'csl'.
Hope this helps,
Henrique
Message 8 of 10
robert06
Perfect, tested.
Thank you, Henrique!
Robert
Message 9 of 10
hmsilva
You're welcome, Robert!
Glad I could help
Henrique
Message 10 of 10
DJGinAZ
Almost 10 years later and another thank you coming your way, Henrique!
