Website is open while opening dwg file
lukas_vavricka
Message 1 of 16
lukas_vavricka
I have this issue which is happening randomly. Sometimes while some of the dwg file is open it's also open the website in my web browser. I sometimes use that website to download blocks or lisp. I think last thing I downloaded is dwg block. Do you know how to get over it? Or at least How something like that is possible?
Thank you
Replies (15)
Message 2 of 16
Moshe-A
@lukas_vavricka hi,
As far as i can understand (hope i am not wrong 😀), bringing a block from website does not create any link to that site on the other hand if the block contain some Hyperlink to that site and you activate that hyperlink from that block, it might open that website. maybe you are running some application (lisp command) that does that?
Moshe
Message 3 of 16
lukas_vavricka
Hello @Moshe-A
Thank you for a response.
The thing is, it happends while opening DWG file. I do the double click on dwg file and file is open in Autocad app, but also at same time my browser open the website.
It's happening randomly, with different files.
So it seems it's not conected to the lisp command directly.
Message 4 of 16
Moshe-A
@lukas_vavricka ,
if you open AutoCAD from its shortcut icon, than use open command, does this also happen?
Message 5 of 16
lukas_vavricka
@Moshe-A
I don't think so.
Message 6 of 16
Moshe-A
@lukas_vavricka ,
In file explorer does the dwg icon is for AutoCAD? if not, make sure AutoCAD DWG Launcher is the application to start it (or at least the AutoCAD Application it self). it sounds like a problem with your OS. are running win10 or win11?
Moshe
Message 7 of 16
lukas_vavricka
@Moshe-A
Yes, I have set launcher for dwg file AutoCAD.  And I am curently using windows 10.
Message 8 of 16
Moshe-A
update to 22h2?
Message 9 of 16
lukas_vavricka
@Moshe-A Yes 22H2
Message 10 of 16
Moshe-A
weird...any event you recall? installing something new? driver? since then
Message 11 of 16
pendean
Community Legend
Community Legend
@lukas_vavricka wrote:
... I sometimes use that website to download blocks or lisp. I think last thing I downloaded is dwg block...
which website is that?
Which blocks or content did you grab from there?
Did you ask them yet, you know, their free blocks, their marketing push to pre-load the website? That's all that seems to be, price you pay for free content I suspect.
Message 12 of 16
Yokaash_Selvam
Delete the temporary files once and after that try to open the dwg file. I hope it will solve your issue, and my guess please check once appload for the default lisp option cleared.
Message 13 of 16
paullimapa
As a test create a new Windows account with local admin privileges. Then sign in using that new account and see if the problem is resolved
Paul Li
IT Specialist
@The Office
Message 14 of 16
Sea-Haven
Sounds to me like as suggested there is a hyperlink in the dwg and it is set to open when you load the dwg.
You may have to look through every object and see if it has a hyperlink. You could then remove the hyperlink. Not sure how to do that.
(setq obj (vlax-ename->vla-object (car (entsel "\nPick object "))))
(vlax-dump-object (vlax-get obj 'Hyperlinks))
look at the "count" if it has hyperlinks it will show > 0
Message 15 of 16
vladimir_michl
Isn't it this?
https://www.cadforum.cz/forum/forum_posts.asp?TID=35669
(an automatic check notifying about an updated version of one of your LISP apps)
Vladimir Michl, www.cadforum.cz  -  www.arkance.world
Message 16 of 16
lukas_vavricka
@pendean  @vladimir_michl So in the end  it was one of the VLX application which was checking it's own updates but it was directed to wrong wabedpage.
I am really suprised that something like that is possible.  I always though that lisp even vlx are scripts running only when the comand is called not independently with acces to the internet.
Thank you for reactions!
