And this can help you?
(defun make_field (obj p / nw_obj)
(setq
nw_obj
(vla-addMtext Space
(vlax-3d-point p)
0.0
(strcat
"{\\fArial|b0|i0|c0|p34;"
"%<\\AcVar ctab>%"
" - Scale 1/"
"%<\\AcExpr (1000/"
"%<\\AcObjProp Object(%<\\_ObjId "
(itoa (vla-get-ObjectID (vlax-ename->vla-object obj)))
">%).CustomScale \\f \"%lu2%qf2816\">%"
") \\f \"%lu2%pr0\">%"
(mapcar
'(lambda (pr val)
(vlax-put nw_obj pr val)
(list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'BackgroundFill)
(list 7 3.5 5 p "Standard" "0" 0.0 -1)
(defun c:Field_Layout_Scale ( / el AcDoc Space js n ent dxf_ent pt_v l h pt)
(vl-load-com)
(foreach el (layoutlist)
(setvar "CTAB" el)
(setq
AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
Space (vla-get-PaperSpace AcDoc)
(setq js
(ssget "_X"
(list
'(0 . "VIEWPORT")
'(67 . 1)
(cons 410 el)
'(-4 . "!=")
'(69 . 1)
(repeat (setq n (sslength js))
(setq
pt_v (cdr (assoc 10 (setq dxf_ent (entget (setq ent (ssname js (setq n (1- n))))))))
l (cdr (assoc 40 dxf_ent))
h (cdr (assoc 41 dxf_ent))
pt (list (- (car pt_v) (* 0.5 l)) (- (cadr pt_v) (* 0.5 h)) 0.0)
(make_field ent pt)
(prin1)
