:VLR-objectModified Reactor triggers before objects in the database are write enabled
westonstout4413
westonstout4413
Seems to be a bug, I would expect given the language of the AutoLISP documentation that :VLR-objectModified would trigger after all objects in the database have completed being modified and are write-enabled, but simply testing (vlax-write-enabled-p <VLA OBJECT>) on the entity which triggered the reactor inside the callback function returns nil. Additionally, running the below code
(progn (while (not (vlax-write-enabled-p <VLA OBJECT>))) (SOME_FUNC) ...)
Never returns true. I have a lot of objects I need to watch, and would prefer not to need to place separate object reactors on each one. My hope was that I'd be able to have one AcDb Reactor to manage changes to entities. As the objects never become write-enabled during the callback function, I cannot make meaningful changes to their data using functions like (VLAX-Invoke)
Am I SOL here?
westonstout4413
Also the case with the docManager reactor :vlr-documentLockModeChanged, strangely.
