vlax-ldata-put
vlax-ldata-put
vmichl_cs
vlax-ldata-put
vmichl_cs
Is it possible to store binary data in DWGs through (vlax-ldata-put)? Are there any size limits?
Restored binary streams seem to be cut off at the first \000 after DWG save/open.
Vladimir Michl
stevor
There is an area called 'binary-to-text encoding' to do just that.
A simple method was used to make a couple virus codes for autocad.
Which is one reason to not load arx or vlx, or fas files,
and be wary of dwgs; from any questionable sources.
S
