vlax-invoke obj 'getattributes returns textstring of *TEXT
DGRL
Advisor Advisor
Message 1 of 25
DGRL
Dear coders
Have some strange outcomes of my code
Want to get the textstring of the ATTRIB and the ATTDEF
If i run the code below i also get back the text string of *TEXT and i wonder why since i am filtering on attribute
If i compare the print out of the block reference with the print out of the attribute definition then i see in the first list also text strings of *TEXT
How do i make sure i only get the text strings of ATTRIB and ATTDEF??
(vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)));get block collection (vlax-for obj blk (cond ( (= "AcDbBlockReference" (vla-get-objectname obj)) (if (= :vlax-true (vla-get-hasattributes obj)) (foreach att (vlax-invoke obj 'getattributes) (print (vla-get-textstring att)) ) ) ) ( (= "AcDbAttributeDefinition" (vla-get-objectname obj)) (print (vla-get-textstring obj)) ) ) ); end of vlax-for obj blk (princ) ); end of vlax-for blk
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Replies (24)
Message 2 of 25
_gile
It should not.
Try this which may help you to diagnose, and if you still have an issue, post the drawing causing this.
(vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) ;get block collection
  (vlax-for obj blk
    (cond
      ((= "AcDbBlockReference" (vla-get-objectname obj))
           (print (strcat "Attribute Reference: " (vla-get-textstring att)))
      ((= "AcDbAttributeDefinition" (vla-get-objectname obj))
       (print (strcat "Attribute Definition: " (vla-get-textstring obj)))
  (princ)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 25
DGRL
@_gile
I will  prepare a dwg for you to test because i get the same result
Thanks for the add you did it makes the print nicer 😄
Found also another thing
When i have block X inserted 5 times it only gives back 1 ATTDEF and 5 ATTREF
Even though it is the same block i need the result to be 5 times ATTDEF and 5 times ATTREF
But this is for later
Kind Regards
Message 4 of 25
DGRL
@_gile
I have to apologize to you.
The reason why i got *text back in the result is because some ***  placed attribute's in the template with fields referring to *text objects in the same template
That's why i thought that the result given contained *text while in fact it is just the text string of the field
Kind Regards
Message 5 of 25
DGRL
@_gile
I still have issues with the length of the list
_$ (length fexpp)
58
_$ (length fexpp1)
55
_$
Any idea what this can be?
it seems that there are  3 ATTRIBS in the block but not as ATTDEF
will dive into this and see what i can find
Kind Regards
Message 6 of 25
_gile
@DGRL wrote:
@_gile
_$ (length fexpp)
58
_$ (length fexpp1)
55
_$
Absolutely none.
I do not know anything about neither fexpp nor fexpp1...
Anyway some block references may have attributes references different from the attribute definitions in the block defefinition* until you synchronize the attributes with ATTSYNC.
* you can insert  some block in the drawing, then edit/add/remove the attribute definitions in the block definition.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 25
DGRL
@_gile
Excuse for not mentioning what fexpp and fexpp1 is
Fexpp   is the (get-text-string) of "AcDbBlockReference" (ATTRIB)
Fexpp1 is the (get-text-string) of "AcDbAttributeDefinition" (ATTDEF)
It is kinda weird that the length of the list for blockreference is 58 and the length of the list for AcDbAttributeDefinition is 55
And attsync had been done but will redo to be sure
will let you know
Kind Regards
Message 8 of 25
_gile
Is there exactly one block reference per block definition (including nested blocks)?
Gilles Chanteau
GileCAD
GitHub
Message 9 of 25
DGRL
i am preparing the dwg for you
might take some time i will filter a lot of working att's out of the dwg for you @_gile
Kind Regards
Message 10 of 25
DGRL
@_gile
After filtering out the working att's i ended up with a different of 5
thats the block inserted 6 times
1 time counted miss 5
Is there a way that i will process every block maybe by ename or handle?
Kind Regards
Message 11 of 25
Sorry, I do not understand what you're trying to achieve.
  (vlax-for obj blk
This expression will iterate through any entity in any 'block definition' (including spaces).
You can trust it, it's more reliable than counting attribute references or definitions by yourself.
Message 12 of 25
DGRL
@_gile
I will re write my code and will let you know the result
Kind Regards
Message 13 of 25
DGRL
@_gile@Anonymous
Take a look at the dwg
1 block
inserted 6 times
below code is result
	(vlax-for obj blk
		(cond
Result
"Attribute Reference: \\W0.8000;1"
"Attribute Reference: \\W0.8000;2"
"Attribute Reference: \\W0.8000;3"
"Attribute Reference: \\W0.8000;4"
"Attribute Reference: \\W0.8000;5"
"Attribute Reference: \\W0.8000;6"
"Attribute Definition: \\W0.8000;DREWSASD" nil
As you can see
6 times REFERENCE
1 time  DEFINITION
I need 6 times REF and 6 times DEF
Kind Regards
Message 14 of 25
ActivistInvestor
Your drawing contains 6 insertions of a block named "AnnoCircle".
What I, and probably most others here are completely baffled by is:
    "I need 6 times REF and 6 times DEF"
What does that mean?  There is only one block definition (and within that, only one attribute definition) in the drawing, along with 6 insertions of the block.
It seems that you're problem stems from a basic misunderstanding of the relationship between the definition and the reference (either blocks or attributes).
You need to provide overview of what your code's ultimate objective is.
@DGRLwrote:
@_gile@Anonymous
1 block
inserted 6 times
	(vlax-for obj blk
		(cond
Result
As you can see
6 times REFERENCE
1 time  DEFINITION
Message 15 of 25
DGRL
@ActivistInvestor
What i mean is,
Since every insert has its own ename
((-1 . <Entity name: 7ffffb53b50>) (0 . "INSERT")
((-1 . <Entity name: 7ffffb53b30>) (0 . "INSERT")
((-1 . <Entity name: 7ffffb53b40>) (0 . "INSERT")
((-1 . <Entity name: 7ffffb53b80>) (0 . "INSERT")
((-1 . <Entity name: 7ffffb53b60>) (0 . "INSERT")
((-1 . <Entity name: 7ffffb53b70>) (0 . "INSERT")
These six insertion which happens to be one block definition  still contains the entget assoc list which as far as i know can be used to access that particular block
And therefore i assumed that it might be possible to generate a list that contains the text string of the ATTRIB and the ATTDEF
The reason why i need to make a list of the text value from both ATTDEF and ATTRIB is quit long and does not add value
Kind Regards
Message 16 of 25
ActivistInvestor
I can see no purpose to generating a list of items that contain data from both the attribute reference (ATTRIB) and the attribute definition (ATTDEF), because the value for the attribute definition in each list element will be the same value, because all of the ATTREFs refer to the same ATTDEF.
What purpose is there to doing that?
@DGRLwrote:
@ActivistInvestor
What i mean is,
Message 17 of 25
DGRL
I need to check drawings containing more then these 6 blocks
And mostly only ,multiple inserts on 1 block definition
some made an error and place what supposed to be the ATTRIB value in the ATT default
Easy to fix only not when you have multiple inserts
But how about this
Even though there are 6 inserts of 1 block definition all the blocks still contains the ATT and therefore there are 6 ATT's
On database level there might be 1 definition but on entity level there are 6.
I still select 6 block or am i wrong thinking like this?
Kind Regards
Message 18 of 25
ActivistInvestor
But how about this
To correct erroneous data in an attribute definition, you don't need the insertions/attributes.  There is only one attribute definition, regardless of how many inserts/attributes of the block exist. I still can't figure out what your ultimate goal is, and without that I can't suggest any way to achieve it.
Message 19 of 25
_gile
The text in an attribute definition got with (cdr (assoc 1 ...)) or (vla-get-TextString ...) is the default value for the attribute reference, in other words, the 'value' of the attribute reference when you insert the block with ATTREQ = 0.
Gilles Chanteau
GileCAD
GitHub
Message 20 of 25
DGRL
@ActivistInvestor
All I need is to access the  ; IAcadAttribute: AutoCAD Attribute Interface which contains the textstring I am after and I need to access the ; IAcadAttributeReference: AutoCAD Attribute Reference Interface
Do a dump of an attdef in a block and see for your self
Kind Regards
