vlax-for limitation?
john.uhden
Mentor Mentor
Message 1 of 8
john.uhden
I am trying to change the PlotStyleName of most of the 200 layers in one drawing.
Using vlax-for on the document's layer collection, it errors out on processing the 65th item...
  (vlax-put Layer 'PlotStyleName name)
; error: AutoCAD.Application: Key not found
The same holds true for vlax-map-collection.
Is there some limitation?  Should I change the collection to a list?  Would an occasional (gc) help?
John F. Uhden
Accepted solutions (3)
Replies (7)
Message 2 of 8
paullimapa
if they both fail on the 65 item perhaps isolate just that layer and see if your code succeeds for that layer:
Also go ahead and try the list alternative and see if it also fails on the 65th item
Paul Li
IT Specialist
@The Office
Message 3 of 8
clindner
I've seen vlax-put statements prefixed with a:
(vl-catch-all-apply
or used like this:
(api-error 'vlax-put-property
I believe this was to have the code continue even if an error is encountered (instead of just dumping out completely).
It's a little over my head, but just throwing it out there fwiw.
Ok, TBH, it's more than a little over my head. 🙄
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
Message 4 of 8
Kent1Cooper
Is that Layer locked?
Kent Cooper, AIA
Message 5 of 8
john.uhden
Oops.  I tried processing a list of the collection. It still errored out on the 83rd or 84th layer of the list.  Of those, 65 layers were changed successfully.  I dumped the "bad" layer and it appeared just fine..  Also, I had done an AUDIT first.
Since I hadn't sent this, I added a catch-all to the code to find out what layer was faulty and why...
"C-TOPO-CTCH-BNDY"  AutoCAD.Application: Key not found
And, yes, it continued processing all the other layers.  YAY!!
Now all I have to do is figure out how to handle viewports.  With the test drawing I was given, changing the global layer PlotStyleName changed the one viewport as well (?)
John F. Uhden
Message 6 of 8
john.uhden
@Kent1Cooper asked "Is that Layer locked?"
Nope.  I'll just have to alert the users that the layer(s) is/are bad and maybe to change the objects on the layer to a new one and delete the bad(s).  They can rename the new layer afterward.
John F. Uhden
Message 7 of 8
paullimapa
Unless the collection is in error only layer objects should be changed and not vport objects. Also may be a good idea to generate a text file report to notify which layers that the code failed on so those can be examined afterwards
Paul Li
IT Specialist
@The Office
Message 8 of 8
john.uhden
Kent,
Might you know where the viewport layer data is stored?
John F. Uhden
