vlax-curve-getclosestpointto doesn't work as expected with splines
dbroad
Mentor Mentor
Message 1 of 11
dbroad
Some may already know this but I couldn't find any documentation about the fact that the only points retrieved from the vlax-curve-getclosestpointto for splines are their control vertiices, NOT THE ACTUAL CURVE.
Try this to test.  I was surprised.
(SETQ E (CAR(ENTSEL "\nSelect a spline object: ")))
(while (setq pt (getpoint "\nPick point: "))
  (command "line" pt (vlax-curve-getclosestpointto e pt) "")
 Even working outside of lisp, perpendicular snaps are unreliable.  Using AutoCAD 2023.
Architect, Registered NC, VA, SC, & GA.
Replies (10)
Message 2 of 11
ronjonp
I don't see that behavior in AutoCAD 2025.
Message 3 of 11
dbroad
This is what I see
After you posted your video, I tested it on AutoCAD 2018 and it worked fine so it must've been a flaw in 2023.
Message 4 of 11
ronjonp
@dbroad
Weird! Must be a bug in the older release. Do you have all your service packs up to date?
Message 5 of 11
dbroad
Just installed SP2023.1.6 but it didn't help.  Weird is an understatement.  Thanks for testing.  Glad it's working in 2025.
Kind of fascinating if it wasn't so frustrating.
Message 6 of 11
daniel_cadext
I tried this in 2021 and 2023, spine type 5 & 6, no issues. Maybe post a sample drawing?
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 7 of 11
phanaem
Hi
Seems like it jumps to Osnap points. I guess the regular Osnap is off, but make sure 3DOsnap (F4) is off as well.
Or just use entmakex.
Message 8 of 11
komondormrex
to be sure that was autocad bug try this
  (command "line" "_non" pt "_non" (vlax-curve-getclosestpointto e pt) "")
Message 9 of 11
dbroad
@phanaem It jumps to the control points rather than the curve itself.
Message 10 of 11
phanaem
Yes, because 3D Osnap is active.
Turn it off with F4, use "_none" in (Command...  line, ore use entmakex for lines.
vlax-curve-getclosestpointto works just fine with Splines.
Message 11 of 11
dbroad
@komondormrex That worked correctly.  I'd turned off the osnaps and cleared all of the osnap choices.  Turned out that the problem was 3DOSMODE.  Thanks everyone.  No real bug but 3DOSMODE could really mess up programs that relate to splines because it's easy to overlook.
