VLA-Rotate Error
VLA-Rotate Error
VLA-Rotate Error
I'm attempting to create a block  from selected objects then rotate that block a specific angle. My code is below.  When running the program it errors out at "(vla-rotate block ipt VPAng)" VPAng is the value I'd like to rotate the block by. IPT is the insertion point of the scaled block. When running with "IPT" I get this error:
"lisp value has no coercion to VARIANT with this type: (29605.1 15304.3 0.0)
 lisp value has no coercion to VARIANT with this type: (29605.1 15304.3 0.0)"
When running with "BPT" as the basepoint I get this error:
"Automation Error: Description Was Not Provided"
Here's my code:
(defun MakeBlock (/ ss bpt name) ;ctrl+shift N
(prompt "\nSelect features for block")
(if (and (setq ss (ssget W)
                         bpt (getpoint "\nSelect Block Base Point")
                         ipt (polar Entpnt (* 1.5 pi) 2000)
                         name (getstring T "\nName: ")
                         yscale ScFac
               (command "_.-BLOCK" name "_non" bpt
                                    ss "" "_.oops" "_.-INSERT"
                                    name "_S" 1 "_R" 0
                                    "_non" ipt
    (princ)
(setq block (entget (entlast))
          block (vlax-ename->vla-object (cdr (car block)))
(vlax-put-property block "YEffectiveScaleFactor" yscale)
(vlax-put-property block "YScaleFactor" yscale)
Can you tell me why it breaks in both cases and what needs to be done to correct it?
Thanks, Brad
I have found the issue. When using "IPT" as the basepoint of rotation, the value needs to be a variant rather than 3d point. The correction is below.
(vla-rotate block (vlax-3D-point ipt) VPAng)
ronjonp
If you want to pass a point use vlax-invoke like so:
(setq block (vlax-ename->vla-object (car (entsel))))
(vlax-invoke block 'rotate (getpoint) pi)
ronjonp
FWIW, your 'AND' statement could return T even if a null value is within .. see example:
;; Returns T
(and (setq a 1
	   b 2
	   c nil
	   d 4
;; Returns nil
(and (setq a 1) (setq b 2) (setq c nil) (setq d 4))
Also, I don't see where 'scfac' is ever set?
"ScFac" was set much earlier in the program. It's much larger than what is shown here. Thanks for the heads up on the And function.
