vla-CheckInterference not working
prountzos509
prountzos509
any idea why
(vla-CheckInterference(vlax-ename->vla-object(car(entsel)))(vlax-ename->vla-object(car(entsel))) :vlax-true :vlax-true)
not working but
(command "-interfere" ...) works ?
want to make an if statement so command route is not suitable and when solids not interfere returns nil
-didier-
Bonjour @prountzos509
I did a test with several objects and when an interference actually exists it is perfectly created by the function.
In the absence of interference, it is NIL that is sent back.
Could I do a test with your objects?
Isolate them and drop the DWG on the forum, please.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
cadffm
my random clean sample
Sebastian
-didier-
Bonjour @cadffm , @prountzos509
actually, there is a problem with the command called this way.
But by using invoke, it would seem that the issue disappears.
(setq test(vlax-invoke obj1 'CheckInterference obj2 :vlax-true :vlax-true))
Is it checked at home?
Amicalement
DA
cadffm
I agree, the bug should be reported. @prountzos509
Sebastian
prountzos509
well more bugs with this
(vla-CheckInterference ob1 ob2 :vlax-false :vlax-false)
because keeps creating the Interference portion of both objects evenif i command lisp not to.
Any idea how we report bugs ?
prountzos509
found it
needs (vla-CheckInterference ob1 ob2 :vlax-false :vlax-true)
