vl-sort help
vl-sort help
zph
Message 1 of 59
vl-sort help
zph
Good day!
Below is an excerpt of code:
(princ "\n qList1: ")(princ qList)
(setq qList (vl-sort qList (function (lambda (x y) (< (car x) (car y))))))
(princ "\n qList2: ")(princ qList)
And below is the what is returned:
 qList1: ((NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-C . 0) (NEW-TEST-VAL-B . 0) (NEW-TEST-VAL-A . 0))
 qList2: ((NEW-TEST-VAL-A . 0) (NEW-TEST-VAL-B . 0) (NEW-TEST-VAL-C . 0) (NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-D . 0))
Why doesn't this instance of vl-sort remove the duplicate dotted pair (highlighted red)?  What am I missing?
Thanks!
~Z
Replies (58)
Message 41 of 59
zph
ActivistInvestor,
Your response answers my question fully.  Thank you.
It seems the general consensus is the built in VL-SORT function is incomplete in its implementation and poorly defines what it does and how it accomplishes it (probably in great part to its incomplete implementation).
Thank you all for the detailed replies.  I have a much greater understanding of this topic.
Cheers!
~Z
Message 42 of 59
_gile
Implementations of two famous sorting algorithms
Insert sort, not the faster but quite simple:
(defun insertsort (fun lst / insert)
  (defun insert	(ele lst)
    (cond
      ((null lst) (list ele))
      ((apply fun (list  ele (car lst))) (cons ele lst))
      ((cons (car lst) (insert ele (cdr lst))))
  (if lst
    (insert (car lst) (insertsort fun (cdr lst)))
More efficient, merge sort:
(defun mergesort (fun lst / merge aggregate)
  (defun merge (fun l1 l2)
    (cond
      ((and l1 l2)
       (if (fun (car l1) (car l2))
	 (cons (car l1) (merge fun (cdr l1) l2))
	 (cons (car l2) (merge fun l1 (cdr l2)))
      (l1)
      (l2)
  (defun aggregate (fun lst acc)
    (cond
      ((cdr lst)
       (aggregate fun
		  (cddr lst)
		  (cons (merge fun (car lst) (cadr lst)) acc)
      ((car lst)
       (aggregate fun
		  nil
		  (cons (merge fun (car lst) (car acc)) (cdr acc))
      ((cdr acc)
       (aggregate fun acc nil)
      (T (car acc))
  (aggregate (eval fun) (mapcar 'list lst) nil)
Gilles Chanteau
GileCAD
GitHub
Message 43 of 59
ActivistInvestor
I asked a simple question, which was what if the function passed into your (sort) function uses the LIST function?
And you say, it is okay as long as I don't try to use the list function within the function'
As long as you don't try to use the list function within what function?  The (sort) function, or the function that's passed into the (sort) function's first argument?
Command: (defun sort (fun list) (mapcar (function (lambda (n)(nth n list))) (vl-sort-i list fun)))
SORT
Command: (setq some-list '(10 4 8 16 2 11 6))
(10 4 8 16 2 11 6)
Command: (sort '(lambda (a b) (apply '> (list a b))) some-list)
; error: bad function: (10 4 8 16 2 11 6)
@john.uhden wrote:
@ActivistInvestor wrote, "What if the function argument (or any function it calls) uses the (list) function?"
You also quoted me... "The lurkers should note that I used list as an argument, which is okay as long as I don't try to use the list function within the function since arguments are treated as local."  But what do you care.  You seem to approve of errors.
Message 44 of 59
john.uhden
Why, within the sort function, of course.  You just demonstrated that.
For all I care, the input argument could be igzlpig, or might that some day become an AutoCAD function?
John F. Uhden
Message 45 of 59
ActivistInvestor
What I show is not the list function being used within the sort function.
What I show is the list function being used in the function that's passed to the sort function.
Since you seem to be misinterpreting what 'within' means, let's try it another way:
(10 4 8 16 2 11 6)
Command: (defun my-comparer (a b) (apply '> (list a b)))
MY-COMPARER
SORT
Command: (sort 'my-comparer some-list)
Backtrace:
[0.80] (VL-BT)
[1.76] (*ERROR* "bad function: (10 4 8 16 2 11 6)")
[2.71] (_call-err-hook #<SUBR @00000000300edde0 *ERROR*> "bad function: (10 4 8
16 2 11 6)")
[3.65] (sys-error "bad function: (10 4 8 16 2 11 6)")
:ERROR-BREAK.60 nil
[4.57] (ill-fun-hk 2 11)
[5.51] (LIST 2 11)
[6.45] (MY-COMPARER 2 11)
[7.39] (#<SUBR @000000002ded8980 nil> (4 . 2) (5 . 11))
[8.34] (sort-i (10 4 8 16 2 11 6) #<SUBR @000000002e03a1b0 MY-COMPARER> nil)
[9.27] (VL-SORT-I (10 4 8 16 2 11 6) MY-COMPARER)
[10.21] (SORT MY-COMPARER (10 4 8 16 2 11 6))
[11.15] (#<SUBR @00000000300113b8 -rts_top->)
[12.12] (#<SUBR @000000002ded8700 veval-str-body> "(sort 'my-comparer
some-list)" T #<FILE internal>)
:CALLBACK-ENTRY.6 (:CALLBACK-ENTRY)
:ARQ-SUBR-CALLBACK.3 (nil 0)
Message 46 of 59
john.uhden
I am not misinterpreting anything.
If a function FOO calls a function BAR and BAR calls the LIST function, then the LIST function falls within the FOO function,
I take it that there wouldn't be a problem naming the input argument IGZLPIG, that is unless I have created an IGZLPIG function that I want to use within the SORT function.  But hat's okay as it will probably just create an error.  Once again, it's up to the author.
John F. Uhden
Message 47 of 59
ActivistInvestor
Any user-defined function should be able to rely on other user-defined functions not changing the definition of built-in, or reserved symbols.
As far as name collisions between user-defined functions verses built-in ones using reserved symbols, higher-order functions should ensure they use sufficiently-unique symbols for local variables, because the problem can occur regardless of whether a local symbol is LIST or IGZLPIG.
And it's not up to the author, it's up to all the authors whose use each other's functions without requiring them to have intimate knowledge of their implementation details.
Message 48 of 59
john.uhden
Well I don't think it's up to @dbroad if I use one of his functions.  It's up to me to learn what it does and how it works.  However it's not up to me if you use one.  In fact it's not up to me if you use one of mine.
John F. Uhden
Message 49 of 59
ActivistInvestor
I see, so what you're trying to suggest is that you are not at fault if your (sort) function fails because the programmer that used it, passed a function that at some point, calls the LIST function. That's entirely the fault of the programmer that used your (sort) function, right?
Message 50 of 59
john.uhden
Well then, I guess that none of us should contribute anything. Might as
well shut this place down.
John F. Uhden
Message 51 of 59
john.uhden
Just to clear up the confusion...
I trust that the symbol names used herein will never be used by Autodesk.
(defun igzlpig-sort (funkshun nput-list)
 (mapcar (function (lambda (n)(nth n nput-list))) (vl-sort-i nput-list funkshun))
Command: (igzlpig-sort '< '("zebra" "ant" "dog" "cat" "ant" "zebra"))
("ant" "ant" "cat" "dog" "zebra" "zebra")
Command: (igzlpig-sort '> '("zebra" "ant" "dog" "cat" "ant" "zebra"))
("zebra" "zebra" "dog" "cat" "ant" "ant")
Command: (igzlpig-sort '> (list 12 pi 9.33 -1 6.67))
(12 9.33 6.67 3.14159 -1)
Command: (igzlpig-sort '< (list 12 pi 9.33 -1 6.67))
(-1 3.14159 6.67 9.33 12)
John F. Uhden
Message 52 of 59
thsa2501
hii,
i want to know how its working lambda function here which i red marked. here, what is (cdr a) &     (cdr b)i am much confusing
kindly clarify me
!list1
((A . 4) (B . 3) (C . 2) (D . 1) (D . 1))
(vl-sort list1 '(lambda (a b) (< (cdr a) (cdr b))));i am confusing here.what input comes here
Message 53 of 59
ВeekeeCZ
The function sorts the given list of pairs by the second members of the pairs.
(cdr '(A . 4)) returns 4.
A very similar example is described in help HERE
Message 54 of 59
_gile
car and cdr are fundamental basics of all LISP dialects.
Gilles Chanteau
GileCAD
GitHub
Message 55 of 59
thsa2501
hi,
thanks for the reply.
'(lambda ( a b) (< (cdr (A . 4)) (cdr (B . 3)))
is this correct?
thanks advance
Message 56 of 59
ВeekeeCZ
No.
What's your goal, post a list before and desired sorted list after.
Message 57 of 59
thsa2501
hi,
thanks for the reply.i know fundamentals of car ,cdr functions.
but, I don't know how its working in lambda function because of (lambda ( a b)).
what is a & b
for example the list(setq lst '((1 2 3) (2 5 6) (4 5 7)))
 (cdr a) =(2 5 6) (4 5 7),it is coming when i put the command line
(cdr b)= ???
thanks advance
Message 58 of 59
Kent1Cooper
@thsa2501 wrote:
.... I don't know how its working in lambda function because of (lambda ( a b)).
what is a & b
(cdr b)= ???
The 'a' and 'b' are stand-ins for the two items in each comparison of pairs of items in the list.  In the case of that sample list, you want the (cadr) function if you want to compare the second items in the sublists -- (cdr) gets the second item from a dotted pair, but from an ordinary list it gets the entire list of items starting with the second one [cuts off the first item].  To get the second item from a [non-dotted-pair] list, use (cadr), which is getting the first item [the a] from the list with its original first item removed [the dr].
Applying the lambda to a list in which the second items of the sublists are all different, so that the order after sorting is apparent:
(setq lst '((1 8 3) (2 4 6) (9 3 0) (4 6 7)))
then
(vl-sort lst '(lambda (a b) (< (cadr a) (cadr b))))
returns
((9 3 0) (2 4 6) (4 6 7) (1 8 3))
What it's doing is saying "When comparing the items in this list, with each possible pair of items to compare [the 'a' and 'b'], if the second item in 'a' is less than the second item in 'b', then 'a' goes before 'b' in the result."
Kent Cooper, AIA
Message 59 of 59
thsa2501
hii kent,
sorry for the delay,
thank you so much for the brief information about what I asked here. i have completely understood now that function.
thanks to everyone who replies to me.
best regards
Hussain
