vl-sort help
vl-sort help
zph
Message 1 of 59
vl-sort help
zph
Good day!
Below is an excerpt of code:
(princ "\n qList1: ")(princ qList)
(setq qList (vl-sort qList (function (lambda (x y) (< (car x) (car y))))))
(princ "\n qList2: ")(princ qList)
And below is the what is returned:
 qList1: ((NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-C . 0) (NEW-TEST-VAL-B . 0) (NEW-TEST-VAL-A . 0))
 qList2: ((NEW-TEST-VAL-A . 0) (NEW-TEST-VAL-B . 0) (NEW-TEST-VAL-C . 0) (NEW-TEST-VAL-D . 0) (NEW-TEST-VAL-D . 0))
Why doesn't this instance of vl-sort remove the duplicate dotted pair (highlighted red)?  What am I missing?
Thanks!
~Z
Replies (58)
Message 2 of 59
rkmcswain
The documentation says (vl-sort) may remove duplicates. Kind of a strange rule for a function IMO. More on that here. Beyone that, Lee Mac has some tools that should help.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 59
ActivistInvestor
@zph wrote:
Good day!
Thanks!
~Z
What determines if vl-sort removes elements is whether they compare as equal using the (eq) function.
Command: (setq list1 '((A . 4) (B . 3) (C . 2) (D . 1) (D . 1)))
Command: (setq list2 (list '(A . 4) '(B . 3) '(C . 2) (last list1) (last list1)))
Command: !list1
Command: !list2
Command: (vl-sort list1 '(lambda (a b) (< (cdr a) (cdr b))))
((D . 1) (D . 1) (C . 2) (B . 3) (A . 4))
Command: (vl-sort list2 '(lambda (a b) (< (cdr a) (cdr b))))
((D . 1) (C . 2) (B . 3) (A . 4))
Command: (eq (nth 3 list1) (nth 4 list1))
nil
Command: (eq (nth 3 list2) (nth 4 list2))
T
Message 4 of 59
zph
rkmcswain,
Thank you for the reply.
Yeah, I saw the specific use of the word *may*; I raised an eyebrow.  Not the most useful explanation I've ever read.
I checked out Lee Mac's functions and I did find one that was able to eliminate the duplicated dotted pair.
Thanks!
~Z
Message 5 of 59
zph
@ActivistInvestor,
Thank you for your reply.  Honestly, your examples didn't make any sense until I researched the EQ function.
I made the assumption that EQ compared items much like = and EQUAL compare values.
From the Autodesk help files:
eq returns nil because f1 and f3, while containing the same value, do not refer to the same list.
Is there a built in sorting function that compares a list's contents using EQUAL instead of comparing lists using EQ?
Message 6 of 59
Ranjit_Singh
In my experience only whole numbers and strings are respected for the equality comparison in vl-sort. Try the following and you will see that real type duplicates are retained, although they might be equal.
Command: (vl-sort '(5.0 1 2 3.0 3.0) '<)
(1 2 3.0 3.0 5.0)
Message 7 of 59
ActivistInvestor
(1 2 3.0 3.0 5.0)
I should have stated that my comments were specifically about how lists are treated.
When given list aruments, the (eq) function indicates if the arguments are the same physical object.
Command: (setq a '(1 2 3))
(1 2 3)
Command: (setq b '(1 2 3))
(1 2 3)
Command: (eq a b)
nil
Command: (eq a a)
T
Message 8 of 59
ActivistInvestor
@zph wrote:
@ActivistInvestor,
No built-in sorting function I'm aware of.
I've used this in the past:
;;  (lsort <list> <comparer>)
;;  <comparer> is a function that takes two arguments,
;;  and returns non-nil if the first argument is greater
;;  than the second, or nil otherwise. The arguments are
;;  the elements of the list to be sorted. This argument
;;  must be quoted.
;;  The default sort order is descending. To change the
;;  sort order to ascending, the <comparer> function can
;;  return the logical complement (not) of it's result.
;; Examples:
;;  1.  Sort a list of coordinates on the Y-component:
;;      Assume unsorted data is in 'UNSORTED
;;    (setq sorted
;;       (lsort unsorted
;;         '(lambda (a b)
;;             (> (cadr a) (cadr b))
;;  2.  Sort a list of entity names by layer:
;;    (setq sorted
;;       (lsort unsorted
;;         '(lambda (e1 e2)
;;            (> (cdr (assoc 8 (entget e1)))
;;               (cdr (assoc 8 (entget e2)))
;;  3.  Sort a list of coordinates on multiple
;;      keys (first by the X ordinate, and then
;;      by the Y ordinate):
;;     (setq epsilon 1e-6)
;;     (defun compare-points (p1 p2)
;;        (cond
;;           (  (equal (car p1) (car p2) epsilon)  ; if x are equal,
;;              (> (cadr p1) (cadr p2)))           ; then compare y,
;;           (t (> (car p1) (car p2)))             ; else compare x
;;     (setq sorted (lsort unsorted 'compare-points))
(defun lsort (input comparer / fun)
   (setq fun (cond (comparer) (t '>)))
   (lsort-aux input)
(defun lsort-aux (input)
   (if (cdr input)
      (  (lambda (tlist)
            (lsort-merge
               (lsort-aux (car tlist))
               (lsort-aux (cadr tlist))
         (lsort-split input)
      input
(defun lsort-split (right / left)
   (repeat (/ (length right) 2)
      (setq
         left (cons (car right) left)
         right (cdr right)
   (list left right)
(defun lsort-merge (left right / out)
   (while (and left right)
      (if (apply fun (list (car left) (car right)))
         (setq
            out (cons (car left) out)
            left (cdr left)
         (setq
            out (cons (car right) out)
            right (cdr right)
   (append (reverse out) left right)
Message 9 of 59
_gile
@zph wrote:
rkmcswain,
Thanks!
~Z
Just to remove duplicated items in a list, you can use this:
(defun distinct (lst)
  (if lst
    (cons (car lst) (distinct (vl-remove (car lst) lst)))
Gilles Chanteau
GileCAD
GitHub
Message 10 of 59
ActivistInvestor
(1 2 3.0 3.0 5.0)
Actually, what vl-sort is comparing is not the values of list elements, it is comparing the list nodes containing the elements for equality (which is what the EQ function does).
In the following example, all three occurrences of 4.0 are the same object:
Command: (setq list1 '(2.0 3 4.0 1.0))
(2.0 3 4.0 1.0)
Command: (setq list1 (cons (caddr list1) (cons (caddr list1) list1)))
(4.0 4.0 2.0 3 4.0 1.0)
Command: (vl-sort list1 '>)
(4.0 3 2.0 1.0)
Message 11 of 59
john.uhden
I guess that's great for numbers, but not so great for strings...
Command: (setq x (list "a" "d" "b" "a" "c" "d"))
("a" "d" "b" "a" "c" "d")
Command: (vl-sort x '>)
("d" "d" "c" "b" "a" "a")
What, doesn't (eq "d" "d")?
Of course, it could work like this:
(defun stringp (x)(= (type x) 'STR))
(if (vl-every 'stringp x)
  (mapcar 'chr
    (vl-sort (mapcar 'car (mapcar 'vl-string->list x)) '>)
("d" "c" "b" "a")
John F. Uhden
Message 12 of 59
_gile
As this remains quite confusing according to how the list to be sorted have been built (as shown by @ActivistInvestor), I'd use two different and more explicit functions: one to sort and remove duplicates and another one to sort and do not remove duplicates.
(defun SortWithoutRemovingDuplicates (lst fun)
  (mapcar '(lambda (x) (nth x lst)) (vl-sort-i lst fun))
(defun SortAndRemoveDuplicates (lst fun / distinct)
    (if lst
  (vl-sort (distinct lst) fun)
Gilles Chanteau
GileCAD
GitHub
Message 13 of 59
ActivistInvestor
  (mapcar 'chr
("d" "c" "b" "a")
vl-sort is not comparing values. It is comparing cons cells. It removes duplicate references to the same cons cell.
It shouldn't matter what kind of data is in a cell.
Command: (setq l1 '("fee" "fie" "foe" "fum"))
Command: (setq l2 (append l1 l1))
("fee" "fie" "foe" "fum" "fee" "fie" "foe" "fum")
Command: (vl-sort l2 '>)
("fum" "foe" "fie" "fee")
Command: (setq l3 (cons "fee" (cons "fie" l2)))
("fee" "fie" "fee" "fie" "foe" "fum" "fee" "fie" "foe" "fum")
Command: (vl-sort l3 '>)
("fum" "foe" "fie" "fie" "fee" "fee")
Command: (setq list1 '(5.25 7 3.25 4.0))
(5.25 7 3.25 4.0)
Command: (repeat 10 (setq list1 (cons (last list1) list1)))
(4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.25 7 3.25 4.0)
(7 5.25 4.0 3.25)
Command: (setq list2 '(5.25 7 3.25 4.0))
(5.25 7 3.25 4.0)
Command: (repeat 10 (setq list2 (cons 4.0 list2)))
Command: (vl-sort list2 '>)
(7 5.25 4.0 4.0 3.25)
Command: (setq list3 (append list1 list2))
(4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.25 7 3.25 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.25 7 3.25 4.0)
Command: (vl-sort list3 '>)
(7 5.25 5.25 4.0 4.0 4.0 3.25 3.25)
Message 14 of 59
john.uhden
This might help:
(defun remdupes (old / new)
  (foreach item old
    (if (not (vl-position item new))(setq new (cons item new)))
  (reverse new)
Command: (remdupes x)
("a" "d" "b" "c")
John F. Uhden
Message 15 of 59
_gile
@john.uhden wrote:
This might help:
  (foreach item old
  (reverse new)
("a" "d" "b" "c")
This reminds me a challenge at TheSwamp.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 59
ActivistInvestor
@_gile wrote:
@john.uhden wrote:
This might help:
  (foreach item old
  (reverse new)
("a" "d" "b" "c")
That was back during a time when AutoLISP's stack was too limited for recursive solutions.
   (distinct-sub lst nil)
(defun distinct-sub (lst dupes)
   (cond
      (  (not lst) nil)
      (  (vl-position (car lst) dupes)
         (distinct-sub (cdr lst) dupes))
      (t (cons (car lst)
                             (cons (car lst) dupes))))
Message 17 of 59
_gile
   (cond
      (  (not lst) nil)
      (t (cons (car lst)
Should not it have been:
(defun distinct (lst / distinct-sub)
  (cond
    (  (not lst) (reverse dupes))
    (t (distinct-sub (cdr lst)
Gilles Chanteau
GileCAD
GitHub
Message 18 of 59
john.uhden
Have you any idea why duplicates are removed from a list of multiple-character strings vs. not removed from single-character strings?
Actually, it's not as simple as that...
Command: (setq a '("d" "dog" "c" "cat" "d" "dog" "b" "bug" "b" "a"))
Command: (vl-sort a '>)
("dog" "dog" "d" "d" "cat" "c" "bug" "b" "b" "a")
Command: (setq b '("dog" "cat" "dog" "b" "b" "a"))
Command: (vl-sort b '>)
("dog" "dog" "cat" "b" "b" "a")
Command: (setq c '("dog" "cat" "dog" "bug" "ant"))
Command: (vl-sort c '>)
("dog" "dog" "cat" "bug" "ant")
Must have something to do with an Englishmun.
John F. Uhden
Message 19 of 59
ActivistInvestor
Hi @_gile.
Actually, it should not have been either of those.
It should have been:
   (cond
      (  (not lst) nil)
      (  (vl-position (car lst) (cdr lst))
         (distinct (cdr lst)))
      (t (cons (car lst) (distinct (cdr lst))))
   (cond
      (  (not lst) nil)
      (t (cons (car lst)
  (cond
Message 20 of 59
marko_ribar
Here is my version, and it will not remove duplicates...
(defun sort ( l f / fun out )
  (defun fun ( l f / k kk )
    (if l
      (progn
        (setq k -1)
        (foreach a l
          (setq k (1+ k))
          (if (vl-every '(lambda ( x ) (apply f (list a x))) (vl-remove-if '(lambda ( x ) (= (vl-position x l) k)) l))
            (setq out (cons a out) kk k)
        (fun (vl-remove-if '(lambda ( x ) (= (vl-position x l) kk)) l) f)
    (reverse out)
  (fun l f)
;;; (sort '(2 4 7 3 5 1) '<) => (1 2 3 4 5 7)
P.S. Quickly written, so there may be some lacks...
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
