vl-mkdir Permissions
dave.mahoney
dave.mahoney
When I use (vl-mkdir "filepath") the folder that is created is read-only.  How do I make it read/write?
setq filepath (getvar "dwgprefix"));gets drawing path
(setq exportfolder "\\2010_version\\")
(setq exportpath (strcat filepath exportfolder))
(vl-mkdir exportpath)
Regards
Dave
Ranjit_Singh
Did you try creating a file in that folder? The read only property of a folder is ignore by windows.
dave.mahoney
Yes, that is where I run into problems as I get "Cannot write to directory:
(defun c:aecexport ()
(setq d (rtos (getvar "CDATE") 2 6)
;get the date and time and convert to text
yr (substr d 1 4)
;extract the year
mo (substr d 5 2)
;extract the month
day (substr d 7 2)
;extract the day
);setq
(setvar "filedia" 0)
(setq filepath (getvar "dwgprefix"));gets drawing path
; sets export path
(if (findfile (strcat filepath "\\2010_version\\"))
(setq export_path (strcat filepath "\\2010_version\\"));; if true
(vl-mkdir (setq export_path (strcat filepath "\\2010_version\\")));; if not
(setq export_dwg_name (getvar "dwgname")); sets drawing name
(princ (strcat export_Path "\n"))
(SETVAR "CMDECHO" 0) ; suppress command line
(command "-aecexporttoautocad"
"f"; Format
"2010"; Year
"b" ; Bind xrefs - Yes/No
"y" ; Yes Bind
"t" ; Bind type=Bind/Insert
"b" ; Bind
"s" (strcat "-" yr "-" mo "-" day) ; YYYY-MM-DD
"" (strcat export_path export_dwg_name)) ; drawing path and name
(setvar "filedia" 1)
(setvar "CMDECHO" 1) ; turn command line on
(princ)
Command: AECEXPORT
C:\Users\Dave.Mahoney\Documents\\2010_version\
File format: 2010
Bind xrefs: Yes
Bind type: Bind
Filename prefix: ACAD-
Filename suffix: -2016-10-25
The folder is created in the correct location but cannot be written to.
The path that is highlighted might have something to do with it but I am not sure why.
Regards
Dave
patrick_35
Hi
And with Scripting.FileSystemObject ?
For example
(setq fso (vlax-create-object "Scripting.FileSystemObject"))
(setq dir (vlax-invoke fso 'createfolder (strcat (getvar "dwgprefix") "\\2010_version")))
(vlax-put dir 'Attributes 16)
(vlax-release-object fso)
dave.mahoney
I get the following with the folder being created
Error: bad argument type: stringp #<VLA-OBJECT IFolder 0000000048050978>
john.uhden
Nice. Worked for me in 2002.
John F. Uhden
patrick_35
Hi
The error occurs when the directory created or modication directory attributes ?
But I will look for more rights issues on the server.
