vl-directory-files for subdirectories
DGRL
Advisor Advisor
Message 1 of 9
DGRL
Dear coders
In 1 of my routines I use vl-directory-files to get all *.dwg in a dir
Now I want to know if it is possible with minor tweaking if vl-directory-files can also read out the subdirectories.
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Replies (8)
Message 2 of 9
john.uhden
From my ACAD2002 help:
vl-directory-files [AutoLISP Reference: VLR]
(vl-directory-files [directory pattern directories])
Arguments
directory
A string naming the directory to collect files for; if nil or absent, vl-directory-files uses the current directory.
pattern
A string containing a DOS pattern for the file name; if nil or absent, vl-directory-files assumes "*.*"
directories
An integer that indicates whether the returned list should include directory names. Specify one of the following:
-1 List directories only.
0 List files and directories (the default).
1 List files only.
;; Function to build a list of drawings found in the specified path and subdirectories:
(defun @find_dwgs (path / spec files spaces dirs @dirs)
  (cond
    ((or (/= (type path) 'STR)(= path ""))
      (setq path
        (strcase
          (vl-filename-directory
            (findfile
              (car (vl-directory-files "" "*.*" 1))
    ((wcmatch path ",*/,*\\"))
    (1 (setq path (strcat path "\\")))
  (setq spec "*.dwg")
  (setq spaces "        ")
  (defun @dirs (path / dirs found)
    (princ (strcat "\rSearching " path (substr spaces (strlen path))))
    (princ)
    (and
      (setq found (vl-directory-files path spec 1))
      (setq found (mapcar (function (lambda (x)(strcat path x))) found))
      (setq files (append files found))
    (and
      (setq dirs (vl-directory-files path "*.*" -1))
      (setq dirs (vl-remove-if (function (lambda (x)(vl-position x '("." "..")))) dirs)
            dirs (mapcar (function (lambda (x)(strcat path x "\\"))) dirs)
    (foreach dir dirs (@dirs dir))
  (terpri)
  (@dirs path)
  (reverse files)
John F. Uhden
Message 3 of 9
_gile
You have to make a recursive search.
(defun allfiles	(folder pattern)
  (apply 'append
	 (cons (if (vl-directory-files folder pattern)
		 (mapcar '(lambda (x) (strcat folder "\\" x))
	       (mapcar '(lambda (x) (allfiles (strcat folder "\\" x) pattern))
		       (vl-remove ".." (vl-remove "." (vl-directory-files folder nil -1)))
Run:
(allfiles dir "*.dwg")
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 4 of 9
DannyNL
Here is my solution.
If you want to scan for files use FileScan, if you only want folders use FolderScan.
;;; FileScan
;;; Usage: (FileScan [Path] [Pattern] [SubFolderScan])
;;; [Path]          - Folder to scan
;;; [Pattern]       - File pattern to search for
;;; [SubFolderScan] - Include subfolders in filescan
(defun FileScan (FS_Path FS_Pattern FS_SubFolders / FS_FileList FS_FolderList FS_ScanList)
   (if
      (and
         (= (type FS_Path)    'STR)
         (= (type FS_Pattern) 'STR)
         (/= (vl-filename-directory FS_Path) "")
      (progn
         (setq FS_Path (strcat (vl-string-right-trim "\\/" FS_Path) "\\"))
         (if
            FS_SubFolders
            (setq FS_FolderList (FolderScan FS_Path T T))
            (setq FS_FolderList (list FS_Path))
         (foreach FS_Folder FS_FolderList
            (setq FS_ScanList   (vl-directory-files FS_Folder FS_Pattern 1))
            (if
               FS_ScanList
               (setq FS_FileList (append FS_FileList (list (list FS_Folder FS_ScanList))))
   FS_FileList
;;; FolderScan
;;; Usage: (FolderScan [Path] [SubFolderScan] [IncludeBase])
;;; [IncludeBase]   - Include [Path] in returnlist
(defun FolderScan (FS_BasePath FS_SubFolders FS_IncludeBase / FS_ScanList FS_FolderList FS_FullPath)
   (if
      (and
         (= (type FS_BasePath) 'STR)
         (/= (vl-filename-directory FS_BasePath) "")
      (progn
         (setq FS_BasePath (strcat (vl-string-right-trim "\\/" FS_BasePath) "\\"))
         (setq FS_ScanList (vl-remove "." (vl-remove ".." (vl-directory-files FS_BasePath "*" -1))))
         (foreach FS_Folder FS_ScanList
            (if
               (not (member FS_Folder FS_FolderList))
               (setq FS_FolderList (append FS_FolderList (list (setq FS_FullPath (strcat FS_BasePath FS_Folder "\\")))))
            (if
               FS_SubFolders
               (setq FS_FolderList (append FS_FolderList (FolderScan FS_FullPath T nil)))
         (if
            (and
               (not (member FS_BasePath FS_FolderList))
               FS_IncludeBase
            (setq FS_FolderList (append (list FS_BasePath) FS_FolderList))
   FS_FolderList
Message 5 of 9
aclarke
What is "." and ".." that is  being removed in your code and shown in the help result linked below?
https://knowledge.autodesk.com/search-result...
Message 6 of 9
_gile
They're used for relative paths. "." stands for current directory and ".." for parent directory.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
dbroad
Hi @_gile ,
Would your function operate any differently if written like this?
(DEFUN allfiles	(folder pattern)
  (APPLY
    'APPEND
    (CONS (MAPCAR '(LAMBDA (x) (STRCAT folder "\\" x))
		  (VL-DIRECTORY-FILES folder pattern)
	  (MAPCAR
	    '(LAMBDA (x) (allfiles (STRCAT folder "\\" x) pattern))
	    (VL-REMOVE ".."
		       (VL-REMOVE "." (VL-DIRECTORY-FILES folder nil -1))
I think the result will be the same and don't expect the timing to be much different.
Architect, Registered NC, VA, SC, & GA.
Message 8 of 9
_gile
No, both are quite similar, the main difference seems to be using uppercase or lowercase 😉
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
dbroad
🙂 Just autoformatted that way. I just took out the if statement.
