Visual Lisp IDE indent
scott_bolton
scott_bolton
Chaps,
I've noticed that, in the last couple of days, the auto-indent format of the IDE has changed. Now instead of two spaces it is four, which means that a heavily nested block of code is VERY wide. Anybody have this or know of a solution? Have I inadvertently changed a setting?
S
roland.r71
@scott_bolton wrote:
Chaps,
S
I'm oldschool, so i use Textpad for all my scripting instead.
But, yeah, you probably changed a setting.
When in the editor, go to: Tools - Environment options - Visual LISP Format Options...
Check the value for: Narrow style indentation (should be 2, it probably says 4 for you)
scott_bolton
Roland, thanks for that, but there is absolutely NO WAY that I accidentally executed a five-step action! Just one of those AutoCAD things I guess.
roland.r71
I would be surprised if you did, without remembering doing so.
But for the moment i can't find an alternative way to set the value.
There doesn't seem to be a sysvar for it, or anything else you might have accidentally changed. At least, i haven't found one yet.
The important thing is, you now know how/where to look Smiley Wink
