CREATE RECTANGLE
CREATE RECTANGLE
Gaganpatel
CREATE RECTANGLE
Gaganpatel
Dear Sir,
I want rectangle create lisp.
cadffm
(command "_.RECTANG" "0,0" "300,120")
(command) is a Lispfunction and command rectang create a closed Polyline in a rectangle shape.
And now, please feel free to ask whatever you want to know in detail.
Sebastian
Kent1Cooper
Will the ordinary RECTANG command not do for you?  If not, what more [options? controls? limitations?] do you need in a routine?
Kent Cooper, AIA
roland.r71
@Kent1Cooper & @cadffm, you guys are to good for this forum.
I'm just struggeling not to answer: "A rectangle can not create lisp."
@Gaganpatel: Please, explain what you want to do, IN DETAIL, using as many words as you can!
Basically, CADffm has answered your (current) question.
Put the command in a lisp, and you have a lisp to create rectangles. (is it usefull; no)
I'm prety sure that's not what you want. Is it? So: Explain what you (realy) want.
stevenharkins
Community Visitor
Community Visitor
   I am extremely new to LISP.  I am trying to create a lisp to create a multitude of rectangles based off of a CSV file.  I was given the below LSP and CSV file; however, for the life of me I can not either run the program or it doesn't seem to work.  Any Help would be greatly appreciated.
dlanorh
You would be better served creating a new question rather than tagging onto an old one
I am not one of the robots you're looking for
Sea-Haven
To confuse a bit more the attached will do dims as well.
Doing rectangs is easy same reading csv, a couple of questions do you want on layer Green etc as per csv, how do you want the rectangs spaced 1 big row ? Or grids if grid is known else could do max x & Y and work out. x=147 y =54 again how many grids sqrt(237)= 15.3948043183407 so a 16x16 grid.
The more complex the more it will approach a pay for service.
