Visual LISP ActiveX Excel API
Message 1 of 8
I found this old post with an attached file, but the link no longer works. Does anyone have a copy kicking around they can post? I can't seem to find any links elsewhere, and Marc-Antonio's listed email is no longer active.
Luke
Replies (7)
Message 2 of 8
Luís Augusto
It's not the same code, but I hope it helps.
Let us know if it worked for your purpose.
Best regards, Luís Augusto
; Program Name: GetExcel.lsp [GetExcel R4]
; Created By:   Terry Miller (Email: terrycadd@yahoo.com)
;               (URL: http://web2.airmail.net/terrycad)
; Date Created: 9-20-03
; Function:     Several functions to get and put values into Excel cells.
; Revision History
; Rev  By     Date    Description
; 1    TM   9-20-03   Initial version
; 2    TM   8-20-07   Rewrote GetExcel.lsp and added several new sub-functions
;                     including ColumnRow, Alpha2Number and Number2Alpha written
;                     by Gilles Chanteau from Marseille, France.
; 3    TM   12-1-07   Added several sub-functions written by Gilles Chanteau
;                     including Cell-p, Row+n, and Column+n. Also added his
;                     revision of the PutCell function.
; 4    GC   9-20-08   Revised the GetExcel argument MaxRange$ to accept a nil
;                     and get the current region from cell A1.
; Overview of Main functions
; GetExcel - Stores the values from an Excel spreadsheet into *ExcelData@ list
;   Syntax:  (GetExcel ExcelFile$ SheetName$ MaxRange$)
;   Example: (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30")
; GetCell - Returns the cell value from the *ExcelData@ list
;   Syntax:  (GetCell Cell$)
;   Example: (GetCell "H15")
; Function example of usage:
; (defun c:Get-Example ()
;   (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30");<-- Edit Filename.xls
;   (GetCell "H21");Or you can just use the global *ExcelData@ list
; );defun
; OpenExcel - Opens an Excel spreadsheet
;   Syntax:  (OpenExcel ExcelFile$ SheetName$ Visible)
;   Example: (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil)
; PutCell - Put values into Excel cells
;   Syntax:  (PutCell StartCell$ Data$) or (PutCell StartCell$ DataList@)
;   Example: (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""))
; CloseExcel - Closes Excel session
;   Syntax:  (CloseExcel ExcelFile$)
;   Example: (CloseExcel "C:\\Folder\\Filename.xls")
; (defun c:Put-Example ()
;   (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil);<-- Edit Filename.xls
;   (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""));Repeat as required
;   (CloseExcel "C:\\Folder\\Filename.xls");<-- Edit Filename.xls
;   (princ)
; );defun
; Note: Review the conditions of each argument in the function headings
; Arguments: 3
;   ExcelFile$ = Path and filename
;   SheetName$ = Sheet name or nil for not specified
;   MaxRange$ = Maximum cell ID range to include or nil to get the current region from cell A1
; Syntax examples:
; (GetExcel "C:\\Temp\\Temp.xls" "Sheet1" "E19") = Open C:\Temp\Temp.xls on Sheet1 and read up to cell E19
; (GetExcel "C:\\Temp\\Temp.xls" nil "XYZ123") = Open C:\Temp\Temp.xls on current sheet and read up to cell XYZ123
(defun GetExcel (ExcelFile$ SheetName$ MaxRange$ / Column# ColumnRow@ Data@ ExcelRange^
  ExcelValue ExcelValue ExcelVariant^ MaxColumn# MaxRow# Range$ Row# Worksheet)
  (if (= (type ExcelFile$) 'STR)
    (if (not (findfile ExcelFile$))
      (progn
        (alert (strcat "Excel file " ExcelFile$ " not found."))
        (exit)
      );progn
    );if
    (progn
      (alert "Excel file not specified.")
      (exit)
    );progn
  );if
  (gc)
  (if (setq *ExcelApp% (vlax-get-object "Excel.Application"))
    (progn
      ;(alert "Close all Excel spreadsheets to continue!")
      (vlax-release-object *ExcelApp%)(gc)
    );progn
  );if
  (setq ExcelFile$ (findfile ExcelFile$))
  (setq *ExcelApp% (vlax-get-or-create-object "Excel.Application"))
  (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Open ExcelFile$)
  (if SheetName$
    (vlax-for Worksheet (vlax-get-property *ExcelApp% "Sheets")
      (if (= (vlax-get-property Worksheet "Name") SheetName$)
        (vlax-invoke-method Worksheet "Activate")
      );if
    );vlax-for
  );if
  (if MaxRange$
    (progn
      (setq ColumnRow@ (ColumnRow MaxRange$))
      (setq MaxColumn# (nth 0 ColumnRow@))
      (setq MaxRow# (nth 1 ColumnRow@))
    );progn
    (progn
      (setq CurRegion (vlax-get-property (vlax-get-property
        (vlax-get-property *ExcelApp% "ActiveSheet") "Range" "A1") "CurrentRegion")
      );setq
      (setq MaxRow# (vlax-get-property (vlax-get-property CurRegion "Rows") "Count"))
      (setq MaxColumn# (vlax-get-property (vlax-get-property CurRegion "Columns") "Count"))
    );progn
  );if
  (setq *ExcelData@ nil)
  (setq Row# 1)
  (acet-ui-progress-init "Atualizando Banco de dados" MaxRow#)
  (setq i 0
	count -1
  (repeat MaxRow#
    (setq Data@ nil)
    (setq Column# 1)
    (repeat MaxColumn#
      (setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
      (setq ExcelRange^ (vlax-get-property *ExcelApp% "Range" Range$))
      (setq ExcelVariant^ (vlax-get-property ExcelRange^ 'Value))
      (setq ExcelValue (vlax-variant-value ExcelVariant^))
      (setq ExcelValue
        (cond
          ((= (type ExcelValue) 'INT) (itoa ExcelValue))
          ((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
          ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
          ((/= (type ExcelValue) 'STR) "")
        );cond
      );setq
      (setq Data@ (append Data@ (list ExcelValue)))
      (setq Column# (1+ Column#))
    );repeat
    (setq *ExcelData@ (append *ExcelData@ (list Data@)))
    (setq Row# (1+ Row#))
    (setq i (1+ i) count (1+ count))
    (acet-ui-progress-safe i)
  );repeat
  (acet-ui-progress-done)
  (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") 'Close :vlax-False)
  (vlax-invoke-method *ExcelApp% 'Quit)
  (setq *ExcelApp% nil)
  *ExcelData@
);defun GetExcel
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (GetCell "E19") = value of cell E19
(defun GetCell (Cell$ / Column# ColumnRow@ Return Row#)
  (setq ColumnRow@ (ColumnRow Cell$))
  (setq Column# (1- (nth 0 ColumnRow@)))
  (setq Row# (1- (nth 1 ColumnRow@)))
  (setq Return "")
  (if *ExcelData@
    (if (and (>= (length *ExcelData@) Row#)(>= (length (nth 0 *ExcelData@)) Column#))
      (setq Return (nth Column# (nth Row# *ExcelData@)))
    );if
  );if
  Return
);defun GetCell
; Arguments: 3
;   ExcelFile$ = Excel filename or nil for new spreadsheet
;   Visible = t for visible or nil for hidden
; Syntax examples:
; (OpenExcel "C:\\Temp\\Temp.xls" "Sheet2" t) = Opens C:\Temp\Temp.xls on Sheet2 as visible session
; (OpenExcel "C:\\Temp\\Temp.xls" nil nil) = Opens C:\Temp\Temp.xls on current sheet as hidden session
; (OpenExcel nil "Parts List" nil) =  Opens a new spreadsheet and creates a Part List sheet as hidden session
(defun OpenExcel (ExcelFile$ SheetName$ Visible / Sheet$ Sheets@ Worksheet)
    (if (findfile ExcelFile$)
      (setq *ExcelFile$ ExcelFile$)
      (progn
        (exit)
      );progn
    );if
    (setq *ExcelFile$ "")
  );if
  (gc)
    (progn
    );progn
  );if
  (if ExcelFile$
      (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Add)
    );if
  );if
  (if Visible
    (vla-put-visible *ExcelApp% :vlax-true)
  );if
  (if (= (type SheetName$) 'STR)
    (progn
      (vlax-for Sheet$ (vlax-get-property *ExcelApp% "Sheets")
        (setq Sheets@ (append Sheets@ (list (vlax-get-property Sheet$ "Name"))))
      );vlax-for
      (if (member SheetName$ Sheets@)
          );if
        );vlax-for
        (vlax-put-property (vlax-invoke-method (vlax-get-property *ExcelApp% "Sheets") "Add") "Name" SheetName$)
      );if
    );progn
  );if
  (princ)
);defun OpenExcel
; Arguments: 2
;   StartCell$ = Starting Cell ID
;   Data@ = Value or list of values
; Syntax examples:
; (PutCell "A1" "PART NUMBER") = Puts PART NUMBER in cell A1
; (PutCell "B3" '("Dim" 7.5 "9.75")) = Starting with cell B3 put Dim, 7.5, and 9.75 across
(defun PutCell (StartCell$ Data@ / Cell$ Column# ExcelRange Row#)
  (if (= (type Data@) 'STR)
    (setq Data@ (list Data@))
  (setq ExcelRange (vlax-get-property *ExcelApp% "Cells"))
  (if (Cell-p StartCell$)
    (setq Column# (car (ColumnRow StartCell$))
          Row# (cadr (ColumnRow StartCell$))
    );setq
    (if (vl-catch-all-error-p
          (setq Cell$ (vl-catch-all-apply 'vlax-get-property
            (list (vlax-get-property *ExcelApp% "ActiveSheet") "Range" StartCell$))
          );setq
        );vl-catch-all-error-p
        (alert (strcat "The cell ID \"" StartCell$ "\" is invalid."))
        (setq Column# (vlax-get-property Cell$ "Column")
              Row# (vlax-get-property Cell$ "Row")
        );setq
    );if
  );if
  (if (and Column# Row#)
    (foreach Item Data@
      (vlax-put-property ExcelRange "Item" Row# Column# (vl-princ-to-string Item))
    );foreach
  );if
  (princ)
);defun PutCell
; CloseExcel - Closes Excel spreadsheet
; Arguments: 1
;   ExcelFile$ = Excel saveas filename or nil to close without saving
; Syntax examples:
; (CloseExcel "C:\\Temp\\Temp.xls") = Saveas C:\Temp\Temp.xls and close
; (CloseExcel nil) = Close without saving
(defun CloseExcel (ExcelFile$ / Saveas)
  (if ExcelFile$
    (if (= (strcase ExcelFile$) (strcase *ExcelFile$))
        (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") "Save")
        (setq Saveas t)
      );if
        (progn
          (vl-file-delete (findfile ExcelFile$))
          (setq Saveas t)
        );progn
        (setq Saveas t)
      );if
    );if
  );if
  (if Saveas
      "SaveAs" ExcelFile$ -4143 "" "" :vlax-false :vlax-false nil
    );vlax-invoke-method
  );if
  (setq *ExcelApp% nil *ExcelFile$ nil)
  (princ)
);defun CloseExcel
; ColumnRow - Returns a list of the Column and Row number
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (ColumnRow "ABC987") = '(731 987)
(defun ColumnRow (Cell$ / Column$ Char$ Row#)
  (setq Column$ "")
  (while (< 64 (ascii (setq Char$ (strcase (substr Cell$ 1 1)))) 91)
    (setq Column$ (strcat Column$ Char$)
          Cell$ (substr Cell$ 2)
    );setq
  );while
  (if (and (/= Column$ "") (numberp (setq Row# (read Cell$))))
    (list (Alpha2Number Column$) Row#)
    '(1 1);default to "A1" if there's a problem
  );if
);defun ColumnRow
; Alpha2Number - Converts Alpha string into Number
; Arguments: 1
;   Str$ = String to convert
; Syntax example: (Alpha2Number "ABC") = 731
(defun Alpha2Number (Str$ / Num#)
  (if (= 0 (setq Num# (strlen Str$)))
    0
    (+ (* (- (ascii (strcase (substr Str$ 1 1))) 64) (expt 26 (1- Num#)))
       (Alpha2Number (substr Str$ 2))
  );if
);defun Alpha2Number
; Number2Alpha - Converts Number into Alpha string
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
  (if (< Num# 27)
    (chr (+ 64 Num#))
    (if (= 0 (setq Val# (rem Num# 26)))
      (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
      (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
    );if
  );if
);defun Number2Alpha
; Cell-p - Evaluates if the argument Cell$ is a valid cell ID
; Arguments: 1
;   Cell$ = String of the cell ID to evaluate
; Syntax examples: (Cell-p "B12") = t, (Cell-p "BT") = nil
(defun Cell-p (Cell$)
  (and (= (type Cell$) 'STR)
    (or (= (strcase Cell$) "A1")
      (not (equal (ColumnRow Cell$) '(1 1)))
    );or
  );and
);defun Cell-p
; Row+n - Returns the cell ID located a number of rows from cell
; Arguments: 2
;   Cell$ = Starting cell ID
;   Num# = Number of rows from cell
; Syntax examples: (Row+n "B12" 3) = "B15", (Row+n "B12" -3) = "B9"
(defun Row+n (Cell$ Num#)
  (setq Cell$ (ColumnRow Cell$))
  (strcat (Number2Alpha (car Cell$)) (itoa (max 1 (+ (cadr Cell$) Num#))))
);defun Row+n
; Column+n - Returns the cell ID located a number of columns from cell
; Arguments: 2
;   Num# = Number of columns from cell
; Syntax examples: (Column+n "B12" 3) = "E12", (Column+n "B12" -1) = "A12"
(defun Column+n (Cell$ Num#)
  (strcat (Number2Alpha (max 1 (+ (car Cell$) Num#))) (itoa (cadr Cell$)))
);defun Column+n
; rtosr - Used to change a real number into a short real number string
; stripping off all trailing 0's.
; Arguments: 1
;   RealNum~ = Real number to convert to a short string real number
; Returns: ShortReal$ the short string real number value of the real number.
(defun rtosr (RealNum~ / DimZin# ShortReal$)
  (setq DimZin# (getvar "DIMZIN"))
  (setvar "DIMZIN" 8)
  (setq ShortReal$ (rtos RealNum~ 2 8))
  (setvar "DIMZIN" DimZin#)
  ShortReal$
);defun rtosr
Message 3 of 8
terrycadd
The website http://web2.airmail.net/terrycad that hosted AutoLISP Exchange, GetExcel and Getting Started with DCL Dialogs has been moved to the new domain https://autolisp-exchange.com . All programs and files are free to download and share. Just click on a button to view the program, then right-click and choose saveas.
Message 4 of 8
co_vs_gio
Hello Terrycadd!
I downloaded the Getexcel R10 lisp -> when using the lisp an error occurred. I am using Cad2007 and Excel 2013
I tried to load (AP) lisp -> enter the command GET-EXAMPLE and PUT-EXAMPLE : on my laptop and PC, both with the same error:
"Command: ap
APPLOAD getxcel.lsp successfully loaded.
Command:
Command: Get-Example Unknown command "GET-EXAMPLE". Press F1 for help.
Command: PUT-EXAMPLE
Unknown command "PUT-EXAMPLE". Press F1 for help."
Then: I tried downloading the R4 version and got the same error ☹️
I read that everyone uses the lisp OK, I am an armateur so I don't know which step I did wrong. I hope you guys can help.
Thank you very much!
Message 5 of 8
Sea-Haven
I started with Getexel and found a few functions that were missing so made my own version, it has a few more functions, note it is Functions that you can use not just use it code, so you do need to have some experience with lisp. A big help was from Fixo who wrote a lot of Excel lisp functions. As I find more or need more functions I add to the program.
I also have similar for Libre Calc. You can use the same functions but open Libre Calc differently.
This will get you started with no excel open.
(setq myxl1 (vlax-get-object "Excel.Application"))
(if (= myxl1 nil)
  (progn
  (setq myxl (vlax-get-or-create-object "excel.Application"))
  (vlax-invoke-method (vlax-get-property myXL 'WorkBooks) 'Add) ; opens a new xl
  (setq myxl myxl1)
(vla-put-visible myXL :vlax-true)
(vlax-put-property myxl 'ScreenUpdating :vlax-true)
(vlax-put-property myXL 'DisplayAlerts :vlax-true)
Message 6 of 8
terrycadd
Hi co_vs_gio,
You can open up GetExcel.lsp in NotePad.exe if you just need to view the AutoLISP code.
Near the top of the file you will see these two example functions that have ";" as the first character of the line.
This means that AutoLISP treats the rest of the line as nothing more than a comment.
So there is really not a function called Get-Example or Put-Example, it is for use as an example only.
;    (GetExcel "C:\\Folder\\Filename.xlsx" "Sheet1" "L30");<-- Edit Filename.extension
;  );defun
;    (OpenExcel "C:\\Folder\\Filename.xlsx" "Sheet1" nil);<-- Edit Filename.extension
;    (CloseExcel "C:\\Folder\\Filename.xlsx");<-- Edit Filename.extension
;    (princ)
;  );defun
In the above example code where you see:
The "C:\\Folder\\Filename.xlsx" needs to be revised to be the actual Windows Folders and the name of the Excel filename.
The "Sheet1" needs to be the actual Tab name in the Excel file that you are needing.
The "L30" means column "L" and row "30", that you are reading up to.
;  Example 1: (GetExcel "C:\\Folder\\Filename.xlsx" "Sheet1" "L30")
;  Example 2: (GetExcel "C:\\Folder\\Filename.xlsx" (list "Sheet1" "Sheet2") (list "L30" "H747"))
I hope this helps explains your questions.
Terry
@co_vs_gio wrote:
Hello Terrycadd!
"Command: ap
Command:
Message 7 of 8
co_vs_gio
Thanks @terrycadd & @Sea-Haven so much!
Message 8 of 8
Sea-Haven
@co_vs_gio & @terrycadd you may find this useful was the answer to jump to an open excel for say input.
; to jump to an existing open program from within CAD
(setq wsh (vlax-create-object "wscript.shell"))
(vl-catch-all-apply 'vlax-invoke-method (list wsh 'AppActivate  "Excel"))
(vl-catch-all-apply 'vlax-invoke-method (list wsh 'AppActivate  "Word"))
(vl-catch-all-apply 'vlax-invoke-method (list wsh 'AppActivate  "Notepad++"))
Note I use Alert to stop cad from continuing with code will do some testing to see if actually needed anymore, the only issue is it needs the same in Excel to jump back to CAD.
