Visibility states doesn't show correct attribute values and position
I'm working with visibility states, and my INSERT has multiple attributes with the same value in different positions for each VS. I'm attaching a simple example with an INSERT named LINE with 2 VS and each line has two attributes called POINT that shows the start and stop point. I did two versions of this block, one w the attributes having a locked position and one that doesn't. Both of them doesn't show the correct attributes values and sometimes it's missing one attribute value as well. I can't seem to find a solution and I'm not too experienced working with blocks and inserts.
Thank you.
Ranjit_Singh
Is this what you are trying to do? See the attached.
@Ranjit_Singh No. All attributes should have the tag named POINT, both VS should share the same ATTRIB with value START but show their respective STOP value. Does it make sense?
Ranjit_Singh
I believe having the same TAG name for all tags is the culprit. Since it worked for me after changing the tag names. Also try posting it here, maybe some advanced dynamic block user knows a trick. I would recommend using the flip parameter and using just one Tag for start and stop. Have the flip action flip the line and tag and then edit the tag to start or stop as desired. Just guessing. Have not tried it.
