Visibility states doesn't show correct attribute values and position
09:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working with visibility states, and my INSERT has multiple attributes with the same value in different positions for each VS. I'm attaching a simple example with an INSERT named LINE with 2 VS and each line has two attributes called POINT that shows the start and stop point. I did two versions of this block, one w the attributes having a locked position and one that doesn't. Both of them doesn't show the correct attributes values and sometimes it's missing one attribute value as well. I can't seem to find a solution and I'm not too experienced working with blocks and inserts.
Thank you.
