ViewPort - Get entities from ViewPort
richie_hodgson
richie_hodgson
Hi, I am going a little potty over something simple. I found a nice lisp that puts the viewport rotation into a north block which works fine when there is a plain viewport, but if you have a polygonal viewport it gets confused between the defining polyline and the viewport so I tried to get it to selection set only the viewport but I am getting  ; error: bad argument type: lentityp nil error. I am using AutoCAD 2016 and Civil3D 2016.
(defun c:rn()
(prompt "\nSelect Objects by Window") ; my tweek
(setq tw (ssget '((0 . "VIEWPORT")))); my tweek
(setq tw (ssadd ent tw)); my tweek
;(setq tw(entget(car(entsel" Select a Viewport:")))) ;original code
(setq new (cdr (assoc 0 tw)))
(cond
((= new "VIEWPORT")(setq rt(cdr(assoc 51 tw))))
((= new "LWPOLYLINE")(setq temp (entget(cdr (assoc 330 tw))))(setq rt(cdr(assoc 51 temp))))
(setq en(car(entsel" Select North Arrow: ")))
(setq elist(entget en))
(setq elist(subst (cons 50 rt)(assoc 50 elist) elist))
(entmod elist)
(princ)
Hope you can help.
Richie
Shneuph
with vlisp:
(Defun c:rn (/ RH-vlVP RH-na)
  (prompt "\nSelect Viewport")
  (setq RH-vlVP (vlax-ename->vla-object (ssname
					   (ssget "_+.:E:S" '((0 . "VIEWPORT")));thanks lee-mac
					   0);ssname
		   );vlax-ename->...
	);setq
  (setq RH-na (vlax-ename->vla-object (car (entsel "\nSelect North Arrow: "))))
  (princ (strcat
	   "\nBlock rotation: "
	   (rtos (cvunit (vla-get-rotation RH-na) "Radians" "Degrees") 2 3)
	   "° matched to\nVP Rotation: "
	   (rtos (cvunit (vla-get-twistangle RH-vlvp) "Radians" "Degrees") 2 3)
	 );princ
  (vla-put-rotation RH-na (vla-get-twistangle RH-vlvp))
  (princ)
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
richie_hodgson
Brilliant.
Richie
