Viewbase default settings
geraldbossink
geraldbossink
I am using the viewbase command quite a lot. Every time I select Base -> from Model Space it come with a standard scale of 0.0006. When using the detail command it comes up with default scale 1:15. Our standard scales are 1:20 for base views and 1:5 for details. Is there a possibility to control these settings?
pendean
Community Legend
Community Legend
You will need to automat with a LISP (if you like to type commands) and/or by editing the (and creating new) button(s) you click on for that command to also include all he parameters you always want all the time @geraldbossink
How would you like to proceed?
geraldbossink
Thnx for your reaction @pendean. Both would be find, which ever is the most easy way. For both I would use a button in the tool palette. In case of migration, that's the easiest way, I think.
imadHabash
When the ribbon is active, this command displays the Drawing View Creation ribbon contextual tab. When the ribbon is not active, use the VIEWEDIT command to change the properties of the base view.
Imad Habash
geraldbossink
I know how to handle base views. It's the default settings that are the problem. With the VIEWEDIT command I change the settings of an existing view. I want to control the settings when I place the view.
