view the Absolute angle with getpoints autolisp
cadking2k5
Message 1 of 12
cadking2k5
Is there a way to view the Absolute angle when you are picking a second point
(setq pt2 (getpoint pt1 "\nSpecify second point" ))
Replies (11)
Message 2 of 12
john.uhden
I presume you would like to see the angle displayed as you are moving your pointer before you actually pick p2. Check out the use of the (grread) function. There also used to be some variable or function to display a line of text somewhere on the screen, but I have forgotten.
John F. Uhden
Message 3 of 12
dbroad
Turn dynmode on.
Architect, Registered NC, VA, SC, & GA.
Message 4 of 12
Kent1Cooper
If you'd like to see that in the Status bar at the bottom [whether or not also in the middle of things with DYNMODE], in Customization for the Status Bar [the little three-horizontal-bars icon at the far bottom right in newer versions], pick Coordinates at the top so it's checked, and set the COORDS System Variable to 2.
Kent Cooper, AIA
Message 5 of 12
john.uhden
Bummer. There's no DYNMODE in 2002.
John F. Uhden
Message 6 of 12
cadking2k5
I have the dynmode on and the DYNDIVIS
Message 7 of 12
dbroad
John,
They need a retired person subscription rate.  Perhaps if you keep contributing to the newsgroup, you will be nominated as a expert elite.  That qualifies you to receive some free software.  I haven't taken advantage of that yet but with subscription rates skyrocketing this year, I might reconsider next year.
Message 8 of 12
dbroad
Experiment with your dynamic input setttings.  See this screencast.
Message 9 of 12
cadking2k5
if it works for you why didn't you show the Absolute angle in your video I didn't see it
Message 10 of 12
Kent1Cooper
I did -- the right-most element in the tool tip at the crosshairs around the middle of the screencast and just before the end.  [If COORDS were set to 2, you would also see it in the Status Bar at the bottom, but in the screencast, that's set for just coordinates, rather than distance and angle.]
Kent Cooper, AIA
Message 11 of 12
cadking2k5
I left out a 3 letter word in the title I want to see the Absolute angle arc
Message 12 of 12
Kent1Cooper
Well, that does make all the difference.  I don't know of a way to do that [but would not claim there isn't one...].  I thought of having a routine draw a Line, during which I had hoped the Dynamic-mode elements would appear, then Erase that and take the LASTPOINT System variable value as the result of what you would have gotten from your (getpoint) function, something like this:
(setq pt1 (getpoint "\nFirst point: "))
(command
  "_.line" "_none" pt1 pause ""
  "_.erase" "_last" ""
(setq pt2 (getvar 'lastpoint))
but it seems Dynamic Mode doesn't operate within (command) functions.
Kent Cooper, AIA
